[VOOM/DISH/OTA] Re: VOOM OTA Module | SatelliteGuys.US
B
bidder522
Guest
I'll go a little more playing... Maybe I can get it to work. I'll
let you know if I need a new OTA module.
Thanks.
--- In VOOM@yahoogroups.com, "Bruce Grodner" <bruceg@h...> wrote:
> Another OTA module or another receiver is about it if you get a
good signal
> from the feed cable into another Digital OTA receiver. I do have
some extra
> VOOM parts, for the most part new, including OTA modules and
Remotes, as
> well as DVI cables. Anything I ship would be tested before
shipping so you
> would know that wasn't the problem anyway if you want to try
that. $12.50
> plus you pay shipping.
> ----- Original Message -----
> From: "bidder522" <jjfisk@s...>
> To: <VOOM@yahoogroups.com>
> Sent: Saturday, July 23, 2005 7:07 AM
> Subject: [VOOM/DISH/OTA] Re: VOOM OTA Module
> > I tried this as well, nothing... (using numbers from
antennaweb). No
> > signal on any RF channel. It appears that the receiver did work
> > previously since there are channel numbers "tuned" previously
(from
> > the knoxville area), which doesn't help since I am in Wisconsin.
> > Anything else I could try?
> > --- In VOOM@yahoogroups.com, "bgrodie" <bruceg@h...> wrote:
> > > There are a variety of possibilities from a bad OTA module to
the
> > > antenna not being peaked. You say it scans but doesn't find
> > > anything. Do you know the RF channel of a jnown good signal?
If so
> > > go into the installation menu, select Aim antenna and manually
input
> > > that two digit number and see if there is any signal on the
signal
> > > strength meter. You will need at least 80? on these VOOM
receivers
> > to
> > > lock a signal. Try all yo0u local channels by digital
channel's RF
> > > number and not the local analog channel number.
> > Yahoo! Groups Links
Yahoo! Groups Links
<*> To visit your group on the web, go to:
http://groups.yahoo.com/group/VOOM/
<*> To unsubscribe from this group, send an email to:
VOOM-unsubscribe@yahoogroups.com
<*> Your use of Yahoo! Groups is subject to:
http://docs.yahoo.com/info/terms/
bidder522 said:
I'll go a little more playing... Maybe I can get it to work. I'll let you know if I need a new OTA module.
Thanks.
If you are not getting any signal at all, I bet it's one of the following:
1. You have an amplified antenna like Winegard Sensar II, but you are not supplying any voltage to it. If that's the case you need to buy a power supply.
2. Bad wiring or poor connection. Disconnect the RG6 cable from the box and connect it to the TV set directly: see if you can get any analog channels at all.
3. You have connected to a wrong connector: there are five cable-type connectors in the back of the DSR-550. You need to use the right-most one (if you look from the back).
See my VOOM STB FAQ (Motorola DSR-550) for pictures and further details: http://www.satelliteguys.us/showthread.php?t=13946
Ilya.
B
B
[VOOM/DISH/OTA] Local Channel Scan comes up with nothing
