VOOM Dish Pointing | SatelliteGuys.US
VOOM Dish Pointing
pipman
9
Hey Guys,
I think my VOOM installer did a bad job aiming my dish since I only get a signal of 85 with a clear/unobstructed view of the sky.
Does anyone know a site where I can calculate the Look Angle for the VOOM satellite?
Any help would be most appreciated. Thanks.
If your satellite signal quality is 85, your dish is already pointed in the right direction. What you can do though is open the the "Aim Satellite Dish" screen in the Installation Wizard, open the window in your TV room, so you could hear the tone and try to move the dish a little bit. Or have some one watch the readings and use a cell-phone to communicate while you are on the roof. This is of course if you are willing to do this on your own. Otherwise, just call VOOM and have them do this for you. Good luck!
Installer Omitted Setup Steps-What Effect?
Signal 85 to 0?
