[VOOM] DVI vs. Component | SatelliteGuys.US
S
Stan Sexton
Guest
DVI should make a difference on a Digital display. After all, the satellite
signal is digital and using a component connection means there is Digital
to Analog to Digital conversion. DVI is digital all the way using a fixed
pixel display.
On a CRT TV, you have Digital to Analog to Analog so Component should be
the best. Using DVI on a CRT means Digital to Digital to Analog. It may not
make a difference at all at best but DVI cables are more expensive than
component so why go that route?
Stan in San Diego
DVI connect will give you a little more detail and sharper edges. Although I using component cables with my Voom stb and DVI with my Bravo D2 DVD player. Also I noticed that there aree less problems using component with the voom stb, right now. Its all amounts to preference.
[VOOM] Re: DVI vs. Component
Agreed CRT prople get better results via component. MY DLP is twice
a s sharp via DVI NOT even close
--- In VOOM@yahoogroups.com, "Stan Sexton" <stanathomesell@c...>
satellite
Digital
a fixed
> pixel display.
should be
It may not
than
> Stan in San Diego
Yahoo! Groups Links
<*> To visit your group on the web, go to:
http://groups.yahoo.com/group/VOOM/
<*> To unsubscribe from this group, send an email to:
VOOM-unsubscribe@yahoogroups.com
<*> Your use of Yahoo! Groups is subject to:
http://docs.yahoo.com/info/terms/
jimmykce1
This message was posted via http://www.satelliteguys.us by jimmykce1
Yahoo! Groups Links
B
RE: [VOOM] Facts and Speculation
M
[VOOM] Help AVS
