I meant if they are both aimed @61.5 they look to my eye they are pointing slightly different(one a little lower then the other)maybe they don't do an exact calibration//thats allSean Mota said:Which one looks more like yours?
rang1995 said:I meant if they are both aimed @61.5 they look to my eye they are pointing slightly different(one a little lower then the other)maybe they don't do an exact calibration//thats all
stevo714 said:They had a hard time answering a question I'm sure someone has an answer here. I got a 2 receiver setup. my question is how do they run OTA from the stealthtenna to both receivers? Splitter? Diplexer? They really could not give me an answer other then they do.
By the way the Rep said the orders are pouring in. I decided to Sign-Up even though my New House won't be done until April 19th. I figured they will pull this promo eventually and also the price goes up $10 on April 1st so signing up now guarenteed my lower price for 2004. Install is set for April 30th and the rep kept saying no hidden costs, no strings attached.
One other question is the lease deal the way to go? $20 for 2 receivers a month is $480 year. Didn't they just lower the price on the receivers?
rang1995 said:so sean if they are aimed at the same spot (i know they are a little off in space but you can even use the old E* dish and get voom) how can that be?? i wonder if i need a more acurate aiming then by hand and walkie talkie (higher,lower higher lower<the number values)
stevo714 said:I thought for sure there would be signal degrade using a splitter. Will they supply 2 pre-amps for both receivers since a few of my towers are about 30 miles away?
Gene:GeneWildershair said:I asked about running a second line rather than using the diplexor, and he said that voom only covers using the diplexor. He never really talked about charging for this, but if that is the case, I'll let him know I'll just do it myself.
WLong said:My camera is dead.
Anyhow, they are not going to be able to install the equipment today. VOOM did manage to get professionals with the correct equipment to come out and do a site survey today and a possible install on Thursday.
I'll let everyone know what the survey folks say.
GeneWildershair said:Just got off the phone with my voom installer. He will be here tomorrow with the equipment. He said he wanted to go over the OTA antenna with me. He said each voom box comes preprogrammed with the ota channels mapped, and problem was, that the channels mapped on my box will not have the proper channels I now recieve from another nearby city? In any case it isn't a huge deal as I could just use my directv box for ota until voom recievers get the ability to scan. I asked about running a second line rather than using the diplexor, and he said that voom only covers using the diplexor. He never really talked about charging for this, but if that is the case, I'll let him know I'll just do it myself. Everything else discussed about the dish, and installation process seemed fine, and it sounded like he knew what he was doing. I asked how many voom installs has he done that were unsuccessful, and he replied "out of the 12 he's done....none", also said that he tries everything to get a signal, and went even further by saying "most no LOS non installs are due to lazy installers." this made me feel better about the install.
Limited time offer
