Also checking my antenna it isn't shaped like a "V" but is straight is this a stealth antenna?
Vick said:I got Voom installed today and the whole thing went so smooth, the installer came on time and it took less than 2 hours to install everything up and running except the OTA antenna. I have Pioneer PDP-1110HD which comes with digital tuner and I decided to but the antenna and install it myself which worked very well. So I told the installer not to bother with OTA thing, but he still installed the module (nice!). As soon as we got signal then I was able to watch in HD. After about 20 minutes the EPG was up and running. I tried different resolutions and found that if I leave it on 720p then I'm able to flip channels faster (slightly) but the STB never crashed after 5 hours of continuous use. So far I am extremely happy with the unit and the service, I even called a friend who has the 43 inch plasma with different provider and told me he never saw a picture as clear as this. I can even watch high definition PIP using the media receiver (neat!).
The only thing is that the time is 1 hour behind and it's supposed to correct itself at midnight.
woodenturkey said:well i got screwed again.....the installer came over shot a azmuth and said that a tree (the same tree my Direct TV points at and works) would block the signal, he didnt even try and see if it would work, he just told me that he was not going to do it because he wont get paid if it does not work(which i find hard to believe) so now i have missed 2 days of work with no service. The installer was rude from the moment he called me on the phone, he didnt give a S**T if i wanted to try another angle(ie in the yard etc.) man i want Voom something fierce but for right now it look loke i will keep watching my direct tv (which is still pointing at a tree)
You can leave it on or standby. Either way will work for downloads.Tvlman said:Post Installation Question: Do you leave your Voom box on all the time like Direct TV so it will download the info? Just a precaution because my Direct TV box really heats up!
kabota dragon said:Total noobie here so I may ask some ignorant questions.
Also - I noticed one of the choices was stretch, where I was hoping it would stretch 4:3 pictures over the length of my tv, but it does not. Instead of I have the bars making my picture 4:3. Any way to change this and if not how long can I watch until I have to worry about static images burning into my screen?
I appreciate your help!
Limited time offer
