Voom Remote UHF? | SatelliteGuys.US
Voom Remote UHF?
softwiz
SatelliteGuys Guru
146
Getting ready to order Voom. Are the Voom remote controls IR or IR/UHF?
Voom remotes are IR. You can buy a small UHF transmitter that replaces one battery in your remote. This will enable UHF operation via your IR remote. You will also need to add an antenna to the UHF coax connector on your receiver.
Below is a link to the thread that talks about the remote. The post later in the thread by myself has a working link for the $24 item you will need to purchase.
Link
"Zoom" button for Voom - hiddem menus?
Can't read Program Guide on Standard Def TV
