Voom setup survey(If I may) | Page 2 | SatelliteGuys.US
OK, I'll bee the odd one on this list.
1. S-video
2. 480i
3. NO diplexer
4. 36" SD RCA
5. 16/03/2004
1. DVI and component (watch via DVI most of the time, but not always)
2. Fixed 1080i
3. No diplexer(two coax) OTA coax is split to feed analog OTA channels to the TV set directly.
4. Sony GWIII (non-XBR) 788p native resolution.
Proud VOOMer since November (Thanksgiving Day).
Two video HDTV displays in same room hook up to one Voom box. 56" wide RPTV-component 1080i, for day viewing. Panny 500U (720p) 65"x116" screen-DVI(auto select) for night viewing.
1. Component on both my HDTV's (Only becuase there is no DVI)
2 Both are 1080i Fixed
3. Diplexor
4. OTA antenna Winegard 7084 HD
5. Runco 60" Rear Projection & Panasonic TAU 36"
Bill
Component
1080i Fixed
1 cable, with a diplexer (not the grey one in the back - a gold/brass one)
Samsung 30" widescreen
Signed up march 11th, upgraded to vavavoom march 26th
1) Component into a Sanyo PLC-XP30 projector (DVI on Sanyo only works with VESA standards)
2) Fixed 720p (tried 1080i - couldn't tell the diffence on a 122" screen! and Auto jumps the 4:3 SD above and below the 16:9 screen, necessitating a zoom down)
3) Separate OTA coax to set (rewired house during total remodel - glad I did!)
btw, joined yesterday 3/29 - painless installation by very knowledgable tech
1) DVI
2) 1080i
3) No Diplexer / One OTA & One SAT
4) Mitsubishi 42313 / 42" CRT RPTV
5) 4/3/04
component.
1080i but I fool around with it and can see little if any difference on HD
no diplexer I get one channel (local PBS) nothing else is broadcasting in digital
Sony ws 57 510 (I think)
optical cable to a Denon surround sound receiver, no sub (it is next) 5 speakers
1) DVI
2) Auto or 1080i
3) No Diplexor (lots of OTA stations in DFW area)
4) Sony 30XBR910
5) 3/19/04
Optical to Sony 685 with Onkyo surrournd experience...my neighbors love me!
1)Component- No DVI and can run it through my receiver.
2)Fixed 1080i-menus look crisper
3)Diplexer- I probably will keep it that way
4)65" Mitsubishi RPTV 2003 Model-WS65711 1080i (converts720p)
Started Vooming 3/23/04.
Sound- Optical out to Yamaha RX-V1400 in 7.1 setup.
1) Component
2) 1080i Fixed
3) Diplexor
4) Panasonic 4U Plasma 42"
3/31/04
1. Was using DVI until update and had rolling blackouts now component
2. 1080i Fixed
3. 2 Cables No Diplexer
4. Mitsubishi WS-55513 HDCP compliant
Vooming Since January 20
Will NE1 post their OTA signal level please?
Sound and Vision HDTV channel Feast
