[VOOM] Two questions: OTA antenna and ESPN HD/ News | SatelliteGuys.US
S
Sean Butler
Guest
Hi,
I'm new to Voom -- had it installed Monday. So far so good -- I get most of
the local's fine, with the notable exception of PBS. :-( I had the
installer split the antenna feed so one goes into the Voom STB and one goes
direct to my TV which has it's own tuner, and both show low to no signal on
that. I have the sensar ii, and it's only about 6 feet off the ground. I
decided not to have the dish and antenna mounted higher until we were sure
it was all going t work. The installer didn't think it would make much
difference and looking at the mapping of channels, I'm not so sure it would
either, without having some kind of large mount high above the roof! I am
curious if any of the other OTA antennas work better than the sensar, such
as the square shooter.
Anyway, I have a 2nd question about ESPN HD and ESPN News. So far, these
two channels are the only two I'm supposed to get that are giving me a
problem. Sometimes they come in, and sometimes they don't. If I change
channels a couple of times (after waiting a few seconds to see if they
tune), they usually do come in. But more often than not, the 1st time I try
it, I get no signal.
I think I read somewhere about some channels having to switch on the LNB or
some such. Is that what is going on? Anyway to improve this?
Thanks,
Sean
------------------------ Yahoo! Groups Sponsor --------------------~-->
Make a clean sweep of pop-up ads. Yahoo! Companion Toolbar.
Now with Pop-Up Blocker. Get it for free!
http://us.click.yahoo.com/L5YrjA/eSIIAA/yQLSAA/EyMolB/TM
Yahoo! Groups Links
<*> To visit your group on the web, go to:
http://groups.yahoo.com/group/VOOM/
<*> To unsubscribe from this group, send an email to:
VOOM-unsubscribe@yahoogroups.com
<*> Your use of Yahoo! Groups is subject to:
http://docs.yahoo.com/info/terms/
I would put you OTA antenna as high as possible. I have my OTA antenna installed in my attic of my two story house and my sat dish is on my roof.
As for the second question, did you receive the newest software 7.20? If not I would wait until you get it and see if this solves your problem. Also try a soft reboot, hold the power button in for about five seconds and release when you see the sat symbol go off , or a hard reboot, which is to unplug the receiver for about five seconds and replug it in.
R
[VOOM] Food Channel now on 616
M
[VOOM] Here I Go Again...2nd try! :)
