Would This Lg Player Accomplish The Same?
[I can't believe it I had it the other day -and returned it after I was done- for the purposes of testing the QAM tuner but did not bother testing the DVD player for quasi-HD PQ!!!
Anyway, here are the specs, and is made by LG/Zenith:
L S T - 3 5 1 0 A
HDTV ATSC/QAM/DVD Player Decoder/Receiver with a built-in HD DVD Player, outputs 1080i from the component video or DVI outputs.
Now available $449.00 Delivered
Very Limited Supply, Order Now!
LST-3510A Product Specifications
• ATSC Tuner for HDTV Terrestrial and QAM Tuner for Digital Cable (Unscrambled)
• All Format HDTV Receiver
• Hi-Format DVD Player (1080i/720p/480p/i)
• 5.1 Channel Dolby® Digital Sound
• DVI with HDCP Connector (HD Video)
• Built-In Enhanced Scaler
• Front Fluorescent Display for Channel/Station
• PSIP-Based Electronic Program Guide
• Unified Remote Control
• Simultaneous analog 480i output
• RS-232 Serial Port
• Enhanced Connectivity Receives ATSC, and QAM (unscrambled) signals and connects to HDTV and analog displays and other devices via RGB, component, s-video, DVI, composite jacks and RF jacks.
• Advanced Functionality Built-in "Hi-Format" DVD player is capable of multi-format Quasi HDTV outputs including 1080i
• 5.1 Channel Dolby® Digital Sound Provides 5.1 channel digital audio from HDTV and DVD sources.
• True Digital Video and Audio Playback via DVI and Dolby® Digital jacks.
• Surf's Up Favorite Channel Selection
