Voom's Program Planner is a PIECE OF SH*T | SatelliteGuys.US
DarrellP
I Think, therefore, I am.
4,298
Salem, OR
I'm glad I came home early tonight, now I will only miss the first 8 minutes of LOST, thank you very much you retarded Fricking software developers at VOOM!
The damned box would not change channels, I kept punching 2 to get to ABC and it only displayed the info. I even went to the Surf Bar to channel 2 and hit Enter and it would not change. Finally I got it to change to CBS then it would go to ABC.
AHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH!! :mad: :mad: :mad: :mad: :mad: :mad:
Maybe that's how Charlie over at E* is working to lower Voom's value for a possible future purchase. He talked them into using Eldon to program their receivers! :D
Terry
P. S.: For the uninitiated, Eldon is the company doing the E* 921. There is ample evidence to lead a number of expert software developers in the forums to conclude that the 921's programmers are essentially incompetent.
That lock-up happens to me too, DarrellP. Not really a lock-up, but where it only shows the info and will not change the channel. I wish I knew what causes that because a reboot is the only solution for me. We have to reboot every morning to be sure.
"I feel your pain."
Is Voom Even Listening About Lousy Installs?
Voom is simply the best!!
