Waht is the Standard VOOM OTA? | SatelliteGuys.US
ryounglaw
17
:confused: :confused: Does anyone know what the standard VOOM OTA is? What is the model? Is it as Sensor II?????
Ryan
yes the standard it the Sensor II , Some people in the begin got the stealth,. but for the most part it was the Sensor II
t
This is what I got in June:
My setup looks identical to Scottie's. Sadly the Winegard is just there to look ugly as they ended up using my existing OTA.
I have the Winegard 4400 and I only get a couple of channels. I'm only 11-15 miles from all stations. Is there anything I can do? Is it possible I just need to reaim the antenna?
Yes i may just need reaimed or it could me that if it is ampified it is to close and you need to kill the power going back to the antenna.
t
Can I still use my voom OTA with DishNet? If so HOW?
Where are the V* and E* birds?
