Wally DVR fee | Page 2 | SatelliteGuys.US
Wally DVR fee
It is a dual-tuner receiver. "Solo" simply refers to the number of TV's that can be connected with independent viewing. (In other words, no TV2 output like the old ViP222 receivers, and no Joeys for other rooms.) There is only one coax input on the back of the Wally because the separator is built-in, unlike the ViP receivers. I am not sure how that works with an RV dish, since I use a regular dish, so someone else will have to weigh-in on that one.
Do you know if recordings on the Wally can be watched with Dish Anywhere?
No, Dish Anywhere would be VOD only. Apparently, with the newer receivers, Dish Anywhere will only play recordings from the internal drive. Since the Wally has no internal drive, there is no Dish Anywhere compatibility for recordings.
Not that I know of, unless they are both turned in to a Dvr by paying the $40.00 one time fee to DISH and adding external hard drives. Then you could switch the external hard drives and share recordings. I know I did this with my older 211ks when I had them on my account years ago.
Reactions: pattykay
That's right, I meant to say two Wally receivers with external hard drives and the $40 DVR service activated. With all that, can recordings on one Wally be watched on the other Wally?
Not unless you manually disconnect the hard drive from one Wally and hook it up to the other Wally to watch it there. There is no way to integrate them or transfer the recordings.
Reactions: MikeD-C05
Not quite. You can transfer a program from one Wally to it's hard drive, then transfer that recording to the other Wally from that hard drive.
Not quite. You can transfer a program from one Wally to it's hard drive...
The Wally has no internal hard drive, so the recordings are already on the external drive.
...then transfer that recording to the other Wally from that hard drive.
You can transfer the entire drive from one Wally to another. Other than that, there is nowhere to transfer the recordings to, for the reason I stated above.
To be technical, there is a way to hook both hard drives up to a computer to transfer files from one drive to another, but that might be a more involved process than the average subscriber would be willing to fool with. I suppose you could just clone the entire hard drive to have access to recordings from the same Wally on both Wally at the same time.
Discounts for HBO?
Is it possible to "backup" teh DVR to EHD
