Sadoun said:To shave the sides of the LNBF feedhorn, you maybe able to do it fast using a bench grinder.![]()
Just a thought![]()
jerryt said:WOW it works!!!!
Got three satellites in a row. 119, 121, and 123. Previously thought as impossible on the T90.
Thanks Iceburg for making me question the 3 degrees limit.
Here are the scan results;
119 = 451 channels
121 = 157 channels
123 = 43 channels
Likvid said:You guys should buy the Smart Titanium 0.2dB LNBs instead as they are very small.
Iceberg said:G10 is tricky due to being on the end of the line. KWTO came in at 75 and 11800 TP was between 58-60, 11720 is low at 30 but stable. I have some working on that one to do
Sadoun said:No need to skew the LNBFs on the T90. The dish skew takes care of that.
jerryt said:Thanks Sadoun and Iceburg.
Yes, that has been my experience, no lnb skew needed with the T90. Makes things much simplier to setup.
Awesome having all the satellites in one dish, but the switching of 8 satellites into 8 receivers, is the part that takes work (and $).
HDTVFanAtic said:Which linear lnbs are you using? Toroidal's, Sadoun's or Extreme as I would think Extremes would give you a better chance at 2 degrees.
http://www.dmsiusa.com/xtreme_lnbf.htm
crawfrdb said:This has not been my experience with linear polarized satellites T90.
The antenna itself seems to be best aligned such that the LNB bar is "illuminated" somewhat, or matches, the arc of the geosync orbit belt. Then I line up my linear LNBFs. Each one has a unique skew, with the LNBF rotated within the ring-clamp for peak signal when attached to the LNB holder. The skew is sometimes zero but sometimes not, depending on the satellite.
crawfrdb said:I note weaker signals with the antenna is aimed & the LNBF is placed away from the center of the LNBF bar vs aiming the antenna directly at the satellite and the LNBF is placed at the center of the bar. Have you observed this?
Did you find the tolerances of the alignment to be very small? If I peak my signals across all LNBFs, and just push the antenna about a degree on any axis with a finger, a noticable decrease in signal is observed. I also notice variations of signal in strong winds as the antenna leaves and then returns fully to the aligned position. After a strong storm, it is always necessary to go back and re-align.
crawfrdb said:I've tried the following LNBFs successfully with my T90:
The stock LNBFs that Wave Frontier sells
QPH-031 Quad (linear ports only, obviously)
XtremeII
KUL-2
All seem to have nearly identical performance.
The XtremeII would definately be the way to go with shaven LNBF holders to try and get closer with linear sats < 3° spaced.
jerryt said:The screw which mounts the LNB holder to the rail is suppose to face back (Iceburg) has it correct, but Labgate and I have the screw facing forward. Having the screw forward allows easy adjustment, but it changes the LNB elevation nose down. That has to be compensated for, or the dish gets poor signal strength and is very sensitive.
jerryt said:Very narrow, but I only run dual LNBs.
crawfrdb said:Are there any linear dual NON-UNIVERSAL LNBFs out there with a NF <=0.3 dB?
jerryt said:Yes, signal is strongest for the center LNB and gets weaker toward the most outboard LNBs.
Alignment tolerances are very small. Azimuth is very forgiving. Elevation has like a 1 or 1.5 degree window, and skew is a compromise (+ or -1 degree) to balance the two outboard LNBs.
Limited time offer
