Way To Hide Unwanted Channels! | SatelliteGuys.US
henderson_tony
48
Okay, so I don't have a way, or maybe I do. More so posing a question. Alot of people want a way to hide unwanted channels, and are happy that the new software allows this for channels under 100. My question: Why not just set up favorite channels ommiting the ones you don't want. I did this awhile ago, and its very convenient. Just wondering?
TONY
Ya good point. Inadvertently i just found myself using the regular channel listing b/c i wanted to start from the channel i was on. So i guess i bounce back and forth. Hmm..maybe an improvement would be for the fav to default to the current channel.
TONY
I have my favorites list set up but sometimes (or usually) I like to surf the channels using the surf bar. It's annoying to have to skip over the movie channels that I don't subscribe to.
I am doing that too, but I find it very inconvenient:
1. I like to browse channels (by pressing ChUp/ChDown). Unfortunately, it is not possible to limit the channel sequence to Favorites only, and browsing through dozens of empty channels is no fun.
2. I can use a colored button in the Surf Bar to surf through Favorites, but it requires several clicks and only works in one direction.
3. I would like to be able to use the Favorites list for its main purpose: to identify several of my favorite channels, not to store the entire list of channels.
Tivo Message about 999
Post ver6.10 fixes
