SatelliteGuys Staff Member Nelson61 has been working HARD on updating our Uplink Report software and data to help us provide you with the most accurate information possible!
Nelson61 has gone through the FCC Database and noticed lots of mistakes in the FCC Database when it comes to the channels affiliation and has painstakingly gone through the FCC Database and compared the information to other sources to try correcting this data so that it is accurate.
If you could please take a moment to check out our listings for your local television market at http://www.satelliteguys.us/thelist/index.php?page=dishnetworkmarkets&sub=true and look over your channels to make sure everything listed is accurate we would appreciate it!
If you do find anything wrong please let us know!
For example...
You take a look at your local FOX station but notice its listed as ABC.
[TABLE="width: 75%, align: center"]
[TR="class: FTA"]
[TD]7383[/TD]
[TD]WTIC (61)[/TD]
[TD]Hartford, CT - ABC, 61[/TD]
[TD]MPEG2 SD[/TD]
[TD]110°W[/TD]
[TD] 20[/TD]
[TD]QPSK (5/6)[/TD]
[TD][SIZE=-2] Spotbeam 04[/SIZE][/TD]
[TD][SIZE=-2]Hartford, CT[/SIZE][/TD]
[TD] [/TD]
[TD]Available
[/TD]
[/TR]
[/TABLE]
Give us as much information as possible, and let us know the correct network so we can correct TheList.
Thanks for your help and for allowing us to make our data even better for YOU!
(And thanks to Nelson61 for all his hard work!!!)
For example...
[TR="class: FTA"]
[TD]7383[/TD]
[TD]WTIC (61)[/TD]
[TD]MPEG2 SD[/TD]
[TD]110°W[/TD]
[TD] 20[/TD]
[TD]QPSK (5/6)[/TD]
[TD] [/TD]
[TD]Available
[/TD]
[/TR]
[/TABLE]
