Weak Eastern Arc Signal Strength | Page 2 | SatelliteGuys.US
you most likely sighted in on the wrong lnb
which box in the checkswitch screen does it show 72.7? it should be in the center ones
I used Port 2 to site the dish as it says in the instructions. I used my receiver to power the meter and LNB. I had the receiver set on 72.7.
I am now hooked up to Port 1 on the LNB.
The box in the "Check Switch" summery is on the 1st box where 61.5 should be.
Well I guess I used port 1 to peak 72.7. I went back and made sure y feedlines at the lnbs were properly hooked up. I had marked them at both ends when I re-made the short cables coming out of the lnbs. This time I double checked that I was hooked up to port 2 for 72.7 and got a better peak on it than before.
I did the "Switch Check" again and had the 3 satellites in the matrix. I went to "point Dish" and I now see all satellites. 61.5 is a little lower than I would like but 72.7 and 77.0 are now up to 58 on each.
Thanks to all for all the help.
HELP! Dish VIP722 Backfeed Setup
