SOLD!! - Weather-covered 8x1 FTA DiSEqC switch | SatelliteGuys.US
SOLD!! Weather-covered 8x1 FTA DiSEqC switch
Not open for further replies.
comfortably_numb
20,238
31,269
Kansas City
Purchased 2 of these brand new from the Czech Republic and ended up only needing 1. New in box. Rare 8x1 weather-covered switch for outdoor use. Also has a terrestrial (OTA) input but I don't know if that functionality works in the US.
I can tell you that this is a high quality switch that can withstand the elements outdoors, unlike Pansat and Amiko switches which are not weatherproof. This switch also has all inputs and outputs going the same direction, which can be handy.
$22 shipped. Paypal only. If you order one of these from the EU, it takes 3-4 weeks to arrive. I ship USPS First Class Parcel.
EMP-Centauri brand
9in/1out 1.1&1.2 switch for up to 8 satellite positions and 1 subscriber, equipped with combiner for terrestrial band. It is designed for switching between 5 to 8 LNBs. Control mode is configured using built-in DIP switch, see Instruction manual for details.
The product allows joining terrestrial band to common downlead.
HDTV and UHDTV compatible
Parameters:
Frequency range
LNB inputs 950-2300 MHz
Terr. input
5-862 MHz
Output
5-2300 MHz
Control
DiSEqC 1.0, 1.1, 1.2 commands
Insertion loss
Sat. 5 dB avg
Terr.
3 dB avg
Sat. inputs isolation
25 dB min
Power consumption
From receiver 50 mA (18 V) + LNB
DC current pass
400 mA max
Dimensions (w,d,h)
11.2 x 11.2 x 4.8 cm
Temperature range
-30 ~ +70 °C
