What cable do I use for a Coolsat 4KPRO? | SatelliteGuys.US
Das Hammer
545
Too close to Ohio
I'm almost positive it is a null modem, but the coolsatusa.com/support site specifically says that the 4000 PRO uses a straight cable. This 4KPRO was redeemed from a guy not really on the up and up. I'm trying to get the 8-03-2005 factory firmware on it and put the factory sat list on it.
--excerpt from coolsatusa.com/support
*The 4000 Plus uses a Null Data Cable
*The 4000 PRO uses a Straight Data Cable
--end excerpt
Thanks. Yous guys are da best.
the 4000 pro does use a straight shot cable
I think my 5000 does too (with 9 receivers I forget which one uses what)
Amc 4
Atlantic bird 3
