What receivers blindscan the arc? | Page 2 | SatelliteGuys.US
If you just press the p.scan button, you aren't allowed to choose more then one satellite, however if you use the menu-auto scan, choose satellites, then p.scan it seems to work.
I will do a little more testing to be sure that it is picking up new TPs.
Bob
Thanks, if that does work the way that you've suggested, I may be retiring my old fortec sooner than I thought (as the Mercury II is actually affordable!) :)
It DOES scan in a new TP with the above steps, however it uses only the default settings for p.scan. i.e. you can't change the frequency steps from 6 Mhz ect. ect. But I deleted a TP and it found it and all the channels that went with it.
Bob
I use my mercury II to blindscan multiple satellites with the motor, works really good. just wish the mercury II was channel master compatible.
Need help in chosing a good receiver
Coolsat 7000, USB HD & .ts files
