I have read that the metal poles should be cut at a 45 degree angle at the end that goes in the ground. Should that be done? Also, how high is too high for the portion sticking out of the ground? Where on line can I find an AT9 install manual?
charlesrshell said:I have read that the metal poles should be cut at a 45 degree angle at the end that goes in the ground. Should that be done? Also, how high is too high for the portion sticking out of the ground? Where on line can I find an AT9 install manual?
This doesn't have any information on a pole mount, but here's a link to the AT9 installation manual http://www.solidsignal.com/manuals/AT9_install_manual.pdfcharlesrshell said:I have read that the metal poles should be cut at a 45 degree angle at the end that goes in the ground. Should that be done? Also, how high is too high for the portion sticking out of the ground? Where on line can I find an AT9 install manual?
charlesrshell said:Thanks Mike500 for the good info. What kinda gravel, quantity, etc do you use in the bottom of the hole?
Limited time offer
