Where is GolTV | SatelliteGuys.US
Where is GolTV
adwan001
55
St. Paul, MN
Could anyone check if they still can get GolTV? It has been a black screen with zero signal quality!! I am afraid it has gone scrambled.
I checked my connections etc and all is in place. :confused:
What type of lnb you have? If you are using linear standard or universal lnb you may not find it on 110W, if you use a dss lnb you will get it.
I am using my old dishnetwork dish connected through a 1X4 switch with another Universal LNB on my Fortec dish setup. I think I just fried another switch. I know, I know, I should turn the receiver off before playing with switches. And I have not touched the switch since installing it just a couple of weeks ago.
Now, thinking what might have caused the problem, I may have ruined the switch by plugging and unplugging the RCA audio and video cables in and out of the VCR when I occasionally taped something. And yes, when I did that the receiver was still on. Do you think that's the problem?
6 foot FortecStar motorized
Ku-Band EPG?
