Which RSN's are Full Time HD and Full Time Simulcasts of their SD counterpart? | SatelliteGuys.US
kovach
419
17
St. Louis
I just like to remove channels from my favorites lists that i'll never watch, and these would be some of them.
Thanks!
if the hd and sd number are the same its a a full time simulcast. easy way to avoid sd is to go to settings, display and select hide sd duplicates.
I have that set, but seems like some of the RSN's show the same thing on both the SD and HD channels. Fox Sports Midwest (channel 671) for instance. Maybe there are some differences, but I haven't seen them.
The HD channels with the "-1" after the 3 digit channel number are the part time HD channels
Is that actually accurate? I've seen, as mentioned in my previous post, Fox Sports Midwest seems to show the same on both all the time, yet there's still a channel xxx-1.
Was hoping this worked better than the "Channels I Get" function. :D
Off-the-record DirecTV Installation
can I use cat5 instead of coax?
