Who makes the best LNB? | SatelliteGuys.US
alaskaman
7
I need a new LNB but I need a real good one as I'm just barely able to receive dishnetwork's 119 satellite signal. Anybody knows who makes the best LNB?
You don't have much choice, if you buy DISH you pretty much get one made by the lowest bidder. If you buy non DISH you will probably get Legacy technology not Dish Pro so your switch options are limited. Probably you will buy a LNB that you don't even know who the real manufacturer is because of private labelling.
Dish in Hawaii, will it work with a SuperDish?
Echostar 10 Utah Spotbeam Footprint
