Amen, Bro! To be honest, the ONLY bug that makes me want to jump out and shout is the problem with recording the OTA sub channels. The rest don't affect or bother me whatsoever.No matter the bugs, to me there's no better DVR out there.
Yes. But certain things can be frustrating.
Posted Via The FREE SatelliteGuys Reader App using an iPhone.
I was having timer issues too. Things like tuners in use when they were not, asking if I want to let something record and switch to that channel when there were 2 available tuners, something says its recording in the guide but it really wasn't. I've pretty much fixed all of that by going into my timers list and deleting a lot of them that were seasonal shows that are not showing new episodes at the moment. Things like X Factor, American Idle, Cake Boss, Little Couple, Pit Bulls and Parolees. All of those are on break till the new season starts. I had at least 25 timers set and deleted almost half of them. I haven't had a timer conflict or glitch since. I DO have the skip back and it switches to live TV by itself glitch, very annoying. I also still can't record OTA sub channels either.
I had to look this up, but channel 47 is a low-power, independent station. Dish doesn't carry that station, do they ? If they don't, you will NOT see any guide data no matter what.I'm in Vegas too, do you notice only few sub-channels have guides? the whole 47.x is missing along with Create and Movie (8.3).
It should, so if it didn't, there's either a problem (bug) or an issue with the guide data. What show are you talking about ?I love how it doesnt record the replay of a show that was skipped due to a conflict even though it shows it will in the schedule. Happened again last night. Showed that it would record the replay of the skipped show at 1am. Looked this morning and of course it did not.
It use to work the way its meant to. Then after one of the updates it stopped. Last night was just an example. This has happened previously. The guide data was fine. I checked it out when I realized that it wasnt recording the original timerIt should, so if it didn't, there's either a problem (bug) or an issue with the guide data. What show are you talking about ?
Anyone else have this happen ?
I have the "Canceled By User" problem too.
Is this the "Canceled by user" bug too ?It use to work the way its meant to. Then after one of the updates it stopped. Last night was just an example. This has happened previously. The guide data was fine. I checked it out when I realized that it wasnt recording the original timer
Limited time offer
