Why is it so hard for them to get it to look decent. I mean it really looks like i'm watching pirated DivX files, with the bad frame rate, audio sync, pixellation. Seriously MPEG4 looks really good if its done right.. they are using H.264, right?
I have to disagree with you. I think they look good. Not as good as OTA but way better the SD and not horrible.chrisw27 said:Why is it so hard for them to get it to look decent. I mean it really looks like i'm watching pirated DivX files, with the bad frame rate, audio sync, pixellation. Seriously MPEG4 looks really good if its done right.. they are using H.264, right?
nicknageli said:Ditto here. I've only got 3 of 5 local HD channels and NBC always looks horrible. I should have waited for them to work the bugs out I'm afraid.
long_time_DNC said:The Seattle HD locals are up now and they look significantly better than their SD counterpart channels.
GeorgeLV said:And the much maligned DirecTV HD channels look significantly better than their SD counterpart channels. You're redefining success to a much lower standard with that statement. They can look significantly better than their SD counterpart channels while at the same time looking significantly worse than their OTA counterpart channels.
waltinvt said:Ahh, someone that can still think objectivly in a world blinded by subjectivity.
Many just can't get it through their head that just because their garbage might not contain dog sh*t it is, in fact, still garbage.
How about, "you can't polish a turd!"Cold Irons said:Man...I will definitely be using this line here at work.....
.....may have to provide you royalties.....
GeorgeLV said:Did you receive OTA before you got your locals over satellite? NBC looks horrible on some programming most everywhere because of Weather Plus.
Limited time offer
