I know...Wonder why I get a signal.not really. home plug works through the AC outlet.
I ran the (2nd) test in broadband install. I can get all VOD. Some are HD/SD instant and some HD say watch in X vs. now.If you're talking about the DishCOMM Setup then yes it's "Online" and searching for other receivers to pair with. Doesn't mean you're actually online.
Also, even if you had DishCOMM set up it's not gonna be able to pull in VoD or DRA. A wireless adapter is much better.
Yup, just tried disconnecting my modem and VOD works. This is an old area, so I guess they crossed the AC lines. That's why I was confused on the need.i did explain this already. he is probably getting it from one of his neighbors with homeplug set up. not supposed to work like that but stranger things have happened.
easy way to tell. kill the power on your router and see if you lose broadband on the receiver. if you do, then some device in your house is providing homeplug to the wiring. if you don't, then thank your neighbor.
keep in mind.. now that you know ... you can get in serious trouble if that someone ever finds you and you're still using their connection. This also gives you ample reason why *not* to use that technology for receiver connections ... accidental misconfig and you're open to everyone on your street getting access...Yup, just tried disconnecting my modem and VOD works. This is an old area, so I guess they crossed the AC lines. That's why I was confused on the need.
That's pretty good. I can't even get my 2 receivers to "see" each other in the same house!![]()
Really?Where the theological place of eternal punishment did they dig that up? Except possibly for a unit for U-Verse, Belkin's been out of the UPS business for several years (2008 or so??).
Limited time offer
