will a h20-100 work with a AU2 dish | SatelliteGuys.US
Peg Leg
2
Indiana
I have a h20-100 rec and use a au9 slimline dish at home. I want to take my h20 rec from my house and put it in my RV for 2 months at a fixed location. I have a extra dish, AU2 with 3 eyes. Will this work with the h20 rec?
The au2 has 4 coax connections. If it will work with the h20, where is the coax hooked up?
My home service has HD but I could survive not having it for the 2 months.
:welcome to Satelliteguys Peg Leg!
Sure, the H20 will work with that dish, but as you noted, no hd. Boo hiss!! :)
On the back of the H20 there should be a coax input marked Sat In, or something like that.
Any one of the connections on the dish will work.
Thanks Chip, Now to get a tripod mount and head for warmer weather.
I see your pic. A friend had a Lark and his old man had a Golden Hawk. I always wanted an Avanti.
Hey Chip and Peg Leg ...
That dish WILL get HD, not sure why you would think it wouldn't, it points at the 99, 101 and 103 , possibly the 110 and 119 as well, depending on what LNB he has.
We've used the AU9 for a long time for HD.
Unless the H20 isn't mpeg4, it's been too long, I can't remember back that far.
Jimbo, Peg Leg has an AU2, not an AU9. It's a variation on the Phase III dish. I think it was used in RVs.
changed to dish 12 mos ago, looks like i am coming home to Direct!!!
Baby First TV
