When I looked it up they wanted $30 for the Kindle for the app. Does it cost anything and does it work with the latest Asus Transformer Tablet? I have it installed on my Android phone and it works fine on it. I have the usb sling adapter.
All he has done is found a work around to get dish Online to work on this device. This is not sideloading your device with DVR content. He can use this device, that apparently isn't compatible with the DRA app yet, and use it with Dishonline.com and the flash player is detected and content will play.
Teehar,
I followed your instruction and got to my receiver just fine. I see my DVR and the serial # to my sling adapter shows etc. but every time that I try to start a recording, a tv show, or movie I get a pop up telling me that I can take my tv anywhere if I just get a sling adapter. It won't play the shows. Any thoughts? Thanks.
hey just wanted to thank you for your instructions, after I loaded the latest all it worked like a charm. btw I was able to load the all directly to my kindle not downloading.
do you happen to know if there is a max go work around since there is no direct app that I've found.
again thanks.
Glad to hear you got it working.Don't think there is a maxgo app for Dish yet.
There is for iOS and android.
If you've already got the Fire, fine. But for $25 more you can get the Nexus 7 instead, and not have to deal with a crippled device.
Yea I'm sure the Nexus 7 is great,I wouldn't mind to try one.That said,my wife and I both love the Kindle Fire's.Root them and you have plenty of neat options.
I have a Kindle Fire HD but I'm not to crazy about rooting it. Dish Remote Access works on it but its not the latest version i.e., the Dish Anywhere App. Can anyone PM me with the apk file with this latest app so I can sideload my Kindle Fire HD. Thanks
http://www.1mobile.com/search.php?keywords=dish+remote+access
This is where I go to get most apps not available via Amazon.
PHP:http://www.1mobile.com/search.php?keywords=dish+remote+access
Could you explain then how to use this website to download the Dish Anywhere android app i.e., the apk file to my PC? I do not believe one can directly download this app to a PC from the Dish Anywhere website. If it is possible, I would like to know. That is why I was hoping someone who has the apk file on their android device to PM me with the file. Thanks
Limited time offer
