I can tell him how to fix that problem but's akin to hacking but you're warmI wonder if Adobe Updater is "upgrading" your installation.
Most software is going in this direction as secure UEFI boot from CDs can be messy.I had to install it on a USB drive as opposed to the CD RW to work.
Or $59.99 for life.They charge $19.99 a month to rent the software for each computer.
Several times a year I suffered a disaster and the clone system was always as fast as I could switch drives and reboot. I used to clone 2 times a week so I was always pretty up to date. In retirement I have few deadlines, really none, so I stopped cloning except once a month. Plus just about any emergency like I just had, I have my Surface Pro that works well for staying connected.I suppose it comes down to how instantaneously you need to be up and running after an event.
I saw that but it's still for one computer and you have to call them to get the software reset everytime you want to reuse it. Not really my idea of a good plan. Especially now that I got compatible that works on win11 with the M.2 driveOr $59.99 for life.
I don't know about windows, but I would imagine there Hass to be something like the snapshot utility on Linux. Moral of the story is, don't try to put all gas in a new motorAfter getting the new Dell / win11 about the way I wanted, I decided to make a clone of the C drive for quick disaster recovery. I use an older CD plus USB to SATA dongle to make a sata drive clone. It seems this software is not compatible with the new computer in some unknown way. The software seemed to load and when I started to launch it to begin cloning the computer locked up and I powered it down. Tried to restart it but it failed POST. Fortunately, Dell had a disaster recovery utility that I was able to trigger and needed to start fresh. It even flashed the BIOS from online ethernet connection to Dell. Just to boot took an hour. It then reloaded windows 11 from the Dell connection. I've spent the last two days reinstalling all my apps and configuring my Desktop the way I like. I then did the windows image of the C drive.
I've never needed to recover from a disaster like this before and always resorted to a clone for quick recovery like a virus attack. I wonder if the windows image backup will put me back like the system was before the attack / disaster or take me back to just having to start all over again.
What do you all use for backup or is anyone else using a C drive clone? I do keep all my install software on a separate drive on my ethernet but the recovery is very time consuming. Obviously, I won't be using my version of Apricorn cloning tool again on this computer. Maybe they have a newer version that works on newer win11.
Most recent article I saw: Apricorn. Get the software safely and easily.
Acronis Home. Used it for years. Create a bootable media and use a USB external HDD.After getting the new Dell / win11 about the way I wanted, I decided to make a clone of the C drive for quick disaster recovery. I use an older CD plus USB to SATA dongle to make a sata drive clone. It seems this software is not compatible with the new computer in some unknown way. The software seemed to load and when I started to launch it to begin cloning the computer locked up and I powered it down. Tried to restart it but it failed POST. Fortunately, Dell had a disaster recovery utility that I was able to trigger and needed to start fresh. It even flashed the BIOS from online ethernet connection to Dell. Just to boot took an hour. It then reloaded windows 11 from the Dell connection. I've spent the last two days reinstalling all my apps and configuring my Desktop the way I like. I then did the windows image of the C drive.
HDD Raw Copy Tool will do that for you pretty easily. I use it all the time. You can make an exact copy of your M.2 to the second M.2 or you can create an image file to write later. Super easy to use.The new Dell computer uses an M.2 NVME C drive so I just invested in an external case for the M.2 to USB and a second 500GB M.2 stick for my clone backup. This way I can just swap the M.2 sticks on the Motherboard and be back up and running. At least that's my plan.
Highly possible cloning the active boot drive will do just that. I know Acronis will.just tried HDDGURU. Looks easy and simple to use. However, it gave me error that it cannot copy the os drive. If I want to clone it then to take the drive out and put in a diff pc so its not the boot drive and do it that way. Unless I did something wrong.
Snapshots in Windows aren't the answer if your ingeniously devised workflow renders your system unbootable with stunning regularity. They're just for simple roll-backs much like you get with Windows System Restore.I don't know about windows, but I would imagine there Hass to be something like the snapshot utility on Linux.
I forgot about Clonezilla. Great advice.Clonezilla will do a drive/partition image as fast as anything. Some will be put off by the text-only interface but it can be "scripted" to some extent.
I took a look at this at:Snapshots in Windows aren't the answer if your ingeniously devised workflow renders your system unbootable with stunning regularity. They're just for simple roll-backs much like you get with Windows System Restore.
Don't confuse detailed with complicated. The human intervention portion of a Clonezilla session should take no more than a couple of minutes.The process is rather complicated. I got Rufus but had trouble creating a boot CD with it.
No! Windows depends on certain blocks (boot and partition sectors) being marked in a particular way and you can't do that with a file copy. Remember SYS C: from DOS?Can the clone of all files on an SSD be simply copy and pasted to an M.2 partition and be inserted into the MB as the main windows 11 OS?
Thanks for saving me that worthless experiment.No! Windows depends on certain blocks (boot and partition sectors) being marked in a particular way and you can't do that with a file copy. Remember SYS C: from DOS?
Limited time offer
