I know you can't upgade from XP to Win 7 direct but can you do the upgrade from xp to vista and then to win 7 in stages?
Registry problems, primaraly.xp to Vista and then vista to 7 would generate SPECIFICALLY what sort of problem and if it does generate issue(s), why isn't there any specific information on it other than speculative hearsay?
Ya, it's really not a speculative heresy thing, but more of a technical rule of thumb, it just isn't ideal to upgrade. It can work, but you need to be prepared to deal with some random-ish issues, both hardware and software that may come up.
In the case of an upgrade disk i believe it has to see an actual Windows installation. In other words it woudl not work ona blank drive.
question? from the posts i am reading i gather i should buy a new computer if i want windows 7 is that right? i am not as computer savvy as most. regardsYa, it's really not a speculative heresy thing, but more of a technical rule of thumb, it just isn't ideal to upgrade. It can work, but you need to be prepared to deal with some random-ish issues, both hardware and software that may come up.
Not necessarily!question? from the posts i am reading i gather i should buy a new computer if i want windows 7 is that right? i am not as computer savvy as most. regards
You only needed to install the software without a key and then reinstall and enter the key on the second installation.
Are you saying that with a Vista upgrade disk you could take a bare drive, install vista without entering the coa key, then "upgrade" your unactivated vista and on that second install enter the key (meaning you wouldn't actually need a previous version)?
Limited time offer
