Wireless USB Adapter | SatelliteGuys.US
You need to either hard wire with ethernet cable into the back of DVR or powerline it according to the instrucions on D* website.
Yes you can, any of them will work, but you have to use your computer to set them up, then attach them to the HR box.
DirecTV suggests the Linksys (Cisco) WGA600N and has the drivers installed on the HR firmware. You can read all about it here:
DIRECTV: Support : Services : On Demand
Now, if you are hoping to use these for MRV, you may be disappointed. They work great for DOD, but MRV is less than perfect. You are better off with a wired solution, maybe powerline adapters, or waiting for Deca.
Speaking of MRV, I just found out about this yesterday. I've also learned man has landed on the moon?
Regardless, neither of my receivers are hooked up to the internet. To get this working, after opting into the beta, do I simply use ethernet cords to connect my two receivers into my modem?
Those are not USB adapters, but have an ethernet connection to the DVR. Both the Linksys WGA600N and WET610N can be set up on the HR2x using the setup menu. Other models of wireless ethernet adapters can be used but will need to be setup using a computer unless both the adapter and router support wi-fi protected setup (WPS).
In many cases, the MRV experience with wireless or powerline will be disappointing.
No USB devices are supported. You need either a wireless gaming device or a wireless bridge. Someone posted some models numbers above. They are NOT USB devices however as, again, not supported.
These connect to the Ethernet port and then "wirelessly" connect to your wireless network. Same as a USB device but uses Ethernet instead (except for the bridge which allows more options).
I realize those are ethernet adapters, I didn't read the usb part of his post, just assumed he was looking for any wireless solution...not enough coffee yet I guess...:rolleyes:
Installer in Atlanta 30327
DIRECTV Adds TV Colombia to DIRECTV Más(TM) Platform
