rogerpl said:I ordered 2 h and 2 j setup for install in two weeks - will return one joey. This seems to be the modus operandi.
I am MOST EAGER to hear how this works for you. I'd send one or maybe both back. I only need the 2H.
Don't forget that a third Hopper will not integrate with the other two. A dual node supports a max of 2 Hoppers and you need a separate node for the third Hopper which means a completely separate MOCA network. In addition, you need 5 lines from the dish which means a couple of DP44 switches since that's the only way to get that number of feeds....I have thought about getting another Hopper and ditching the Joey altogether, Joey for me is a little limited.
apparently they will if you connect the nodesDon't forget that a third Hopper will not integrate with the other two. A dual node supports a max of 2 Hoppers and you need a separate node for the third Hopper which means a completely separate MOCA network. In addition, you need 5 lines from the dish which means a couple of DP44 switches since that's the only way to get that number of feeds.
How do I go about ordering a additional hopper? I hate the dumb joeys specially when the hopper is using all the tuners?
So how much are you folks paying for the 2nd Hopper?
Limited time offer
