Bandstacking LO operation remains the same with double channel scans on each polarity..
What post(s) are you referencing that this was fixed?
Carlos43,
Are firmware update notes provided as to what is fixed?
Downloaded the firmware update, performed factory reset and the DVR timers do not execute. No one else using the DVR function?
the default timer setting is schedule,which just changes channels when the time comes.
You have to change the setting to record instead of schedule.
I didn't try it with the may 20 firmware but I have used timers with the previous versions with no problems.
X2/XAT web page updated and now there are files available s for download. A new release which is undergo testing will be release in a day or two.
http://www.x2sat.com/x2-hd
AC 3 audio channels still cut off after about 30minutes with this newest file....Channel up/down fixes it for another 30minutes or so.
Limited time offer
