Given that lnb's are one of the least expensive components in the system, putting the approx $20.00 price difference aside, which one would you choose and why? Is it worth saving $20.00 bucks? Is the invacom really too heavy?
Iceberg said:for me the Invacom was too heavy. It stuck out too far on the back so it moved the arm which screwed my numbers. If you have a way to reinforce the arm it will be fine
I like the Xtreme. Very lightweight and low profile![]()
TiminMb said:Wow! The weight actually sags the arm? Doesn't sound like a good idea for a single arm mount.
TiminMb said:The guy wires sound like a good idea. Even monofilament fishing line would work.
Did the 90cm supposed to be 1.0m dish have a single arm, or a twin supports on the sides?
I think I'm switching to a 1.0m dish ASAP. If that doesn't do it fully, then its on to a 0.3 extreme of Invacom 0.3. This hobby reminds me of the arms race.
Limited time offer
