Amazon sells the Firestick Lite (HD) for $19.95 but that's not the average price, it's the loss leader. 4K versions are $29.95 and up.Where is the average price for a Firestick 20 bucks??
I bought 3 on sale for $24.4K versions are $29.95 and up.
With the DishAnywhere app open, select the guide and scroll to any listing. Pressing << will bring up the direct entry ring.My only gripe with the Fire Stick is the remote/interface makes it difficult to maneuver. I have trouble going directly to the channel I want to watch on my Hopper. I had it figured out once but haven't used it much and can't seem to find the trick. There was a method that used the round outer ring of the "mouse" to clumbsily enter channel numbers. Maybe they changed the software.
Do those prices require a Prime membership, or is that only required for the Free one-day shipping?
I added the Ethernet adapter to my Firestick and it works awesome.I like the Roku Ultra, it has an ethernet connection, which is better than wifi. But it is more expensive than Firestick, but under $100 and worth it.
Right here, sorry, I was off by 1 cent. 19.99Where is the average price for a Firestick 20 bucks??
Only required for the 1 day shipping.Do those prices require a Prime membership, or is that only required for the Free one-day shipping?
I also added the wired Eithernet adapter to my Fire TV Cube. Super smooth steaming and doesn't rely on wi-fi as sometimes my access points will reboot themselves.I added the Ethernet adapter to my Firestick and it works awesome.
Not sure what the Ultra has, but you can get a Roku 4K right now for $30 bucks.I like the Roku Ultra, it has an ethernet connection, which is better than wifi. But it is more expensive than Firestick, but under $100 and worth it.
The Lite isn't a good choice for the kindve streaming he's taking about
Then $5 more gets you more, $10 more gets you a lot more.The Lite isn't a good choice for the kindve streaming he's taking about
I'm probably much more advanced and deep into what you're talking aboutThen $5 more gets you more, $10 more gets you a lot more.
Either way, my point it's a one time expense, one and done.
The + or the wireless Joeys?Setting up my first one with 2 Wireless Joey 4's. Royal PITA so far.
Both, Although, the plus was just a bad unit but these wireless Joeys are not great. And they only work with android TV. In other words you cannot use them without the Hopper plus. I assume the Joey 4 is the same. Once I finally got through it, the interface is really cool, and the Hopper 3 and the Joeys there was a little bit of lag so it's not as fast as what we're used to but it's not annoyingly slow, either.The + or the wireless Joeys?
$15 adds Ethernet to any Firestick.Most of these Firestick work off wifi only, no ethernet connection. The Roku Ultra has an ethernet connection, which is more reliable than wifi.
Limited time offer
