Ditto on the drive and ditto on it being trouble-free.My LaCie 500gb with Samsung drive and 16mb cache works fine, but I did have problems at first until I discovered that the power cable on back of drive needed to be pushed in with more force.
Good choice. Good drives with enclosures is the way to go as opposed to pre-made.
Only drives I've ever had fail on all my servers, desktops, and laptops have been WD.WD in my opinon is hands down better drive than seagate. The failure rate is much higher on the seagate. I purchase and install hundreds of drives. I've found that WD is less prone to failure. Maxtor is the worst of any drive I've used.
Yes, as long as you only have one powered up at a time.Can I get a USB hub and add another drive, keeping two in place ?
Only drives I've ever had fail on all my servers, desktops, and laptops have been WD.[/QUO
Provide the name manufacture of drive you have the best performance from. As I said earlier, I have used hundreds of each brand and found the failure rate on the WD to lowest. I guess its kind of luck of the draw as to the drive that fails the least
I have Seagate Cheetah SCSI 3 10K and 15K drives in my servers, Seagate Barracuda 7200.9s in my desktops, and I have replaced several laptop drives of various brands, Toshiba is the latest to fail, with Seagate Momentum 7200rpm drives. My 2 external drives for my 622 at home are Seagate DB35.3 AV drives in generic enclosures using the Cypress chipset, currently the best for ata drives.
The drives I have replaced have all been Western Digital, Toshiba, and Fujitsu drives. I have not had to replace a Seagate yet. I've been doing this since my first hard drive was a 10MB MFM.
Just picked up a Western digital 500gb Essential hard drive last night. Is there a way to shut down the hard drive or is it even necessary? I moved some programming to it last night with no problems. Only issue was with CNN trying to load its enhanced features, without me asking it to, locked up DVR and stopped transfers.
I unplugged hard drive when not in use, any other way or should I bother.
They do have a switch. They boot up either from the receiver rebooting itself every night or some other reason. They unplug from the rear, it's really not a problem unless the drive is somehow not easy to access.Does it not have a power switch? Keep it off when not using it.
Did it come with a firmware utility to disable turning on at system start up?They do have a switch. They boot up either from the receiver rebooting itself every night or some other reason. They unplug from the rear, it's really not a problem unless the drive is somehow not easy to access.
If it has a switch I can't find it- I'll check again- unplugging not a problem.They do have a switch. They boot up either from the receiver rebooting itself every night or some other reason. They unplug from the rear, it's really not a problem unless the drive is somehow not easy to access.
Mine is later model no circle but blue lineThe switch is the button in the circle.
Limited time offer
