Man, they will kill you now !![]()
Nah.... It's in public domain now. I've been a good boy
S~
I'm confused.No, my video locking/blocking/pixelating is off the Sat feed while audio stays stable. Happens once during a show for about 5-10 seconds and then the rest of the broadcast is fine.
So, the chronology seems to be:I've been using it for about two weeks. Audio drops on Fox and ABC appear to be addressed correctly. I haven't had any problems with it.
I'm confused.
Only hours before, you posted:
- For two weeks you used it without problems.
- Someone else gets it and mentions some pixelation.
- Now you see some pixelation.
That seems to be that the pixelation is actually only a recent event, that is likely to be in the source, rather than caused by the software, since you used it for two weeks without noticing any obvious pixelation.
A "grand total of 4 people" are the only ones to have problems, yet Dish stopped the rollout of the update. Hmmm...Based on the fact that a grand total of 4 people report problems ... I would not jump to conclusions.
I think a grand total of 4 people here received it.
I watched the DVR'd event of "are You Smarter than a Fifth Grader" off the Fox40 Sat Feed this morning and about 1/2 way through there was 5 seconds of video breakup/blocking/pixelating. Again. Audio remained stable.
S~
Anyone that got 6.15 have a Seagate EHD, Dish was supposed to be fixing the sleep mode problem.
Didn't happen.
I went through my usual unplug-then-plug the Seagate Freeagent EHD and noticed the folders (yea!) and then came back an hour later knowing that the EHD would have gone to sleep and went to My Media and none of the recordings are shown. The available space is right, but it's the same ol' symptoms as 6.14.
Thanks for nothing, Dish.
If this update was supposed to fix the update, then, it is a miserable, terrible failure at first glance. I watched a recording of last week's Chuck tonight, and the dropouts were worse than ever. It was almost unwatchable and accompanied by pixellation galore -- and that's brand-new.
I will confirm later to see if new recordings exhibit the same behavior.
This is getting old.
This release is going out by zip codeI did not get the updated software. How many people really got it. Only Four?
See RandallA's post
http://www.satelliteguys.us/1625512-post467.html
Apparently to areas that have had problems related to the previous fix. And it is fairly specific on what it fixes. I for example do not have proplems, even with ABC(720p) in NY DMA. But other areas, for example SF have, problems that are suppose to be fixed.
Limited time offer
