3/11/2009 12:24pm - Uplink Activity Report - 90 changes | SatelliteGuys.US
D
DigiSAT Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 3/11/2009 12:24pm - 90 changes
Uplink Comparison Range: 03/11/2009 11:53A - 03/11/2009 12:24P
Channel Additions:
125 - PIRTV [MPEG2 SD] added to Anik F3 118.7W TP 23 ConUS beam (NA)
125 - PIRTV [MPEG2 SD] added to Ciel-2 129W TP 21 ConUS beam (NA)
125 - PIRTV [MPEG2 SD] added to EchoStar11 110W TP 03 ConUS beam (NA)
125 - PIRTV [MPEG2 SD] added to EchoStar1 148W TP 15 ConUS beam (NA)
125 - PIRTV [MPEG2 SD] added to EchoStar3 61.5W TP 08 ConUS beam (NA)
371 - BETJ [MPEG4 HD] added to Ciel-2 129W TP 29 ConUS beam (A)
371 - BETJ [MPEG4 HD] added to EchoStar3 61.5W TP 16 ConUS beam (A)
573 - PIRTV [MPEG2 SD] added to Anik F3 118.7W TP 23 ConUS beam (NA)
573 - PIRTV [MPEG2 SD] added to Ciel-2 129W TP 21 ConUS beam (NA)
573 - PIRTV [MPEG2 SD] added to EchoStar11 110W TP 03 ConUS beam (NA)
573 - PIRTV [MPEG2 SD] added to EchoStar1 148W TP 15 ConUS beam (NA)
573 - PIRTV [MPEG2 SD] added to EchoStar3 61.5W TP 08 ConUS beam (NA)
5184(4) - WTTV [MPEG4 HD] added to EchoStar5 129W TP 05 ConUS beam (NA)(Bloomington, IN-N/A)
6134 - RTVI+ [MPEG2 SD] added to EchoStar3 61.5W TP 14 ConUS beam (A) (H)
6135 - INTER [MPEG2 SD] added to EchoStar3 61.5W TP 31 ConUS beam (A) (H)
6405(39) - WSFL [MPEG4 HD] added to EchoStar10 110W TP 12 Spotbeam 01 (NA)(Miami, FL-CW)
7934(32) - WVIRD [MPEG2 SD] added to Ciel-2 129W TP 15 Spotbeam 39 (NA)(Charlottesville, VA-NBC)
9480(320) - SHOTO [MPEG4 HD] added to Ciel-2 129W TP 23 ConUS beam (A)
9480(320) - SHOTO [MPEG4 HD] added to Echostar12 61.5W TP 23 ConUS beam (A)
9481(327) - TMC-E [MPEG4 HD] added to Ciel-2 129W TP 24 ConUS beam (A)
9481(327) - TMC-E [MPEG4 HD] added to Echostar12 61.5W TP 23 ConUS beam (A)
9513(321) - SHOCS [MPEG4 HD] added to Ciel-2 129W TP 23 ConUS beam (A)
9513(321) - SHOCS [MPEG4 HD] added to EchoStar3 61.5W TP 22 ConUS beam (A)
19807 - TXT7 [175] added to EchoStar1 148W TP 15 ConUS beam (NA)
19809 - TXT9 [175] added to EchoStar1 148W TP 15 ConUS beam (NA)
19819 - TXT19 [175] added to EchoStar1 148W TP 15 ConUS beam (NA)
19830 - TXT30 [175] added to EchoStar1 148W TP 15 ConUS beam (NA)
19831 - TXT31 [175] added to EchoStar1 148W TP 15 ConUS beam (NA)
36855 - DNL7 [143] added to EchoStar9 121W TP 21 ConUS beam (A)
36857 - DNL6 [143] added to EchoStar9 121W TP 21 ConUS beam (A)
Channel Removals:
4804 - TMP34 (NA) removed from Ciel-2 129W TP 24 ConUS beam
4804 - TMP34 (NA) removed from Echostar12 61.5W TP 23 ConUS beam
4819 - TMP49 (NA) removed from Ciel-2 129W TP 29 ConUS beam
4819 - TMP49 (NA) removed from EchoStar3 61.5W TP 16 ConUS beam
4822 - TMP52 (NA) removed from Ciel-2 129W TP 23 ConUS beam
4822 - TMP52 (NA) removed from Echostar12 61.5W TP 23 ConUS beam
4823 - TMP53 (NA) removed from Ciel-2 129W TP 23 ConUS beam
4823 - TMP53 (NA) removed from EchoStar3 61.5W TP 22 ConUS beam
7391 - KTKA (NA) removed from Echostar12 61.5W TP 05 Area 8 beam(Topeka, KS-ABC)
7393 - KSNT (NA) removed from Echostar12 61.5W TP 05 Area 8 beam(Topeka, KS-NBC)
7394 - KTMJ (NA) removed from Echostar12 61.5W TP 05 Area 8 beam(Topeka, KS-N/A)
9016 - WHP (NA) removed from EchoStar8 77W TP 01 ConUS beam(Harrisburg, PA-CBS)
9051 - WTEV (NA) removed from EchoStar8 77W TP 05 ConUS beam(Jacksonville, FL-CBS)
9053 - WAWS (NA) removed from EchoStar8 77W TP 05 ConUS beam(Jacksonville, FL-FOX)
9353 - KLRT (NA) removed from EchoStar8 77W TP 09 ConUS beam(Little Rock, AR-FOX)
36853 - DNL12 (A) removed from EchoStar9 121W TP 21 ConUS beam
Channel Moves:
579 - INTER [MPEG2 SD] moved from EchoStar3 61.5W TP 31 ConUS beam to EchoStar3 61.5W TP 18 ConUS beam (A) (H)
593 - RTVI+ [MPEG2 SD] moved from EchoStar3 61.5W TP 14 ConUS beam to EchoStar3 61.5W TP 18 ConUS beam (A)
Channel Package Flag Changes:
152 - CBS C [MPEG2 SD] - EchoStar11 110W TP 05 ConUS beam changed package flags (A)
152 - CBS C [MPEG4 SD] - Echostar6 72.7W TP 05 ConUS beam changed package flags (A)
5180(6) - WRTV [MPEG4 HD] - EchoStar5 129W TP 05 ConUS beam changed to Available (H)(Indianapolis, IN-ABC)
5181(8) - WISH [MPEG4 HD] - EchoStar5 129W TP 05 ConUS beam changed to Available (H)(Indianapolis, IN-CBS)
5183(59) - WXIN [MPEG4 HD] - EchoStar5 129W TP 05 ConUS beam changed to Available (H)(Indianapolis, IN-FOX)
5250(32) - WNCF [MPEG4 HD] - Ciel-2 129W TP 08 Spotbeam 43 changed to Available (H)(Montgomery, AL-ABC)
5250(9) - KEZI [MPEG4 HD] - Ciel-2 129W TP 14 Spotbeam ?? changed to Available (H)(Eugene, OR-ABC)
5252(12) - WSFA [MPEG4 HD] - Ciel-2 129W TP 08 Spotbeam 43 changed to Available (H)(Montgomery, AL-NBC)
5252(16) - KMTR [MPEG4 HD] - Ciel-2 129W TP 14 Spotbeam ?? changed to Available (H)(Eugene, OR-NBC)
5253(20) - WCOV [MPEG4 HD] - Ciel-2 129W TP 08 Spotbeam 43 changed to Available (H)(Montgomery, AL-FOX)
5253(34) - KLSR [MPEG4 HD] - Ciel-2 129W TP 14 Spotbeam ?? changed to Available (H)(Eugene, OR-FOX)
5260(3) - KATC [MPEG4 HD] - Ciel-2 129W TP 11 Spotbeam 42 changed to Available (H)(Lafayette, LA-ABC)
5261(10) - KLFY [MPEG4 HD] - Ciel-2 129W TP 11 Spotbeam 42 changed to Available (H)(Lafayette, LA-CBS)
5262(15) - KADN [MPEG4 HD] - Ciel-2 129W TP 11 Spotbeam 42 changed to Available (H)(Lafayette, LA-FOX)
5271(46) - KION [MPEG4 HD] - Ciel-2 129W TP 13 Spotbeam 32 changed to Available (H)(Monterey, CA-CBS)
5272(8) - KSBW [MPEG4 HD] - Ciel-2 129W TP 13 Spotbeam 32 changed to Available (H)(Salinas, CA-NBC)
5273(35) - KCBA [MPEG4 HD] - Ciel-2 129W TP 13 Spotbeam 32 changed to Available (H)(Salinas, CA-FOX)
5280(3) - KEYT [MPEG4 HD] - Ciel-2 129W TP 15 Spotbeam 32 changed to Available (H)(Santa Barbara, CA-ABC)
5281(12) - KCOY [MPEG4 HD] - Ciel-2 129W TP 15 Spotbeam 32 changed to Available (H)(Santa Maria, CA-CBS)
5282(6) - KSBY [MPEG4 HD] - Ciel-2 129W TP 15 Spotbeam 32 changed to Available (H)(San Luis Obispo, CA-NBC)
5283(24) - KKFX [MPEG4 HD] - Ciel-2 129W TP 15 Spotbeam 32 changed to Available (H)(San Luis Obispo, CA-N/A)
6371(4) - KTVX [MPEG4 HD] - Ciel-2 129W TP 01 Spotbeam 18 changed to Available (H)(Salt Lake City, UT-ABC)
6389(13) - KTRK [MPEG4 HD] - Echostar12 61.5W TP 13 Area 3 beam changed to Available (H)(Houston, TX-ABC)
6390(11) - KHOU [MPEG4 HD] - Echostar12 61.5W TP 13 Area 3 beam changed to Available (H)(Houston, TX-CBS)
6391(2) - KPRC [MPEG4 HD] - Echostar12 61.5W TP 13 Area 3 beam changed to Available (H)(Houston, TX-NBC)
6392(26) - KRIV [MPEG4 HD] - Echostar12 61.5W TP 13 Area 3 beam changed to Available (H)(Houston, TX-FOX)
6393(39) - KIAH [MPEG4 HD] - Echostar12 61.5W TP 13 Area 3 beam changed to Available (H)(Houston, TX-CW)
6442(4) - KRON [MPEG4 HD] - EchoStar7 119W TP 07 North California beam changed to Available (H)(San Francisco, CA-MNT)
8375(20) - KTXH [MPEG4 SD] - Echostar12 61.5W TP 13 Area 3 beam changed to Available (H)(Houston, TX-MY)
8376(8) - KUHT [MPEG4 SD] - Echostar12 61.5W TP 13 Area 3 beam changed to Available (H)(Houston, TX-PBS)
8377(51) - KNWS [MPEG4 SD] - Echostar12 61.5W TP 13 Area 3 beam changed to Available (H)(Katy, TX-N/A)
8378(45) - KXLN [MPEG4 SD] - Echostar12 61.5W TP 09 Area 3 beam changed to Available (H)(Rosenberg, TX-UNI)
8379(47) - KTMD [MPEG4 SD] - Echostar12 61.5W TP 09 Area 3 beam changed to Available (H)(Galveston, TX-N/A)
8380(67) - KFTH [MPEG4 SD] - Echostar12 61.5W TP 09 Area 3 beam changed to Available (H)(Alvin, TX-TEL)
8381(57) - KAZH [MPEG4 SD] - Echostar12 61.5W TP 09 Area 3 beam changed to Available (H)(Baytown, TX-TEL)
8382(55) - KTBU [MPEG4 SD] - Echostar12 61.5W TP 09 Area 3 beam changed to Available (H)(Conroe, TX-N/A)
8384(61) - KZJL [MPEG4 SD] - Echostar12 61.5W TP 09 Area 3 beam changed to Available (H)(Houston, TX-N/A)
8385(34) - KUVM [MPEG4 SD] - Echostar12 61.5W TP 09 Area 3 beam changed to Available (H)(Dewalt, TX-N/A)
8386(14) - KETH [MPEG4 SD] - Echostar12 61.5W TP 13 Area 3 beam changed to Available (H)(Houston, TX-TRIN)
9495(152) - CBS C [MPEG4 HD] - Ciel-2 129W TP 20 ConUS beam changed package flags (A)
9495(152) - CBS C [MPEG4 HD] - Echostar12 61.5W TP 21 ConUS beam changed package flags (A)
19210 - FANDO [DATA] - EchoStar11 110W TP 06 ConUS beam changed package flags (A)
Channels in the system: 6522
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
Looks like Pirate tv is back... Last time that was up, there was a smart card swap going on and only the pirates could see that channel.
Yep... that's exactly it. To my surprise that channel is not encrypted. Any legal FTA receiver can watch it. I checked it out on 110 and it's just some guy talking about how they a securing their signal and lists the channel types that will be impacted in "Early 2009". But I guess it should be put up there as not encrypted.
Lafayette locals in HD! YAY!
Congrats! Let us know how they look.
And to others wondering on the Lafayette, LA locals they have 3 out of 3 since there isn't an NBC station in their DMA. Wonderful DMA rules.... at least WVLA out of Baton Rouge has a 1000kw HD OTA signal you can pick up pretty easily in Lafayette.
Amazing, isn't it? I don't remember the time when this actually happened in the last few years.
Sure it has. Most of the time they don't say anything until AFTER. But they have pre-announced things on several occasions.
The most memorable was when Discovery, TLC, History, et. al., went live a couple of summers ago. They announced dates for those more than a month in advance, as I recall.
I think the same thing happened with some regional sports networks, as well. But I am getting old and I could be wrong.
Just confirmed with my mother in Ville Platte they are up and running. They looking great...
Too bad they cannot provide guide data for KALB and KPLC. Those are the 2 NBCs easily available in Evangeline Parish. Since Lafayette is on the bird now, maybe I will try re-pointing to BR on my next visit. WVLA may be a stretch from there...
Can't wait to get home from work tonight and check out our Indy locals! Woohoo! Not having NBC kind of sucks, but, hey..... not going to complain. I'm happy!:tux:
D
3/13/2009 10:51am - Uplink Activity Report - 2 changes
D
3/12/2009 2:04am - Uplink Activity Report - 139 changes
