Same here - the picture quality was great too, with just one or two minor break-ups in the picture. I hope Dish continues to expand their 1080p content!
I checked that out and mine says:Menu 6, 3, Analysis, HDMI Test, then look at the info 2 screen on the Disp. Info.
Supported type: 1080i, 1080p60, etc.
Doed that mean that I can't view "The Beast 1080p"? Because I can't get the normal download to work. It tells me that I have to download a different version of the episode. My TV does not do 1080p/24Hz.
I was hoping the L618 would fix The Beast in 1080p for me, but it doesn't look like it did - unless I'm doing something wrong. I even tried a prior download of an episode - but it was downloaded the same way the the message prior to download about the format maybe not being compatible.
Thanks for your advice anyone...
Based on the test your TV does not support 1080p/24 and that is what the show is delieverd in. There is nothing you can do (well almost nothing short of buying an external scaler)...
That said my TV also does not support 1080p/24 either BUT...and here is the part that will have you going HUG?!?!....I get the option to play it anyway and it does.
Obviously not in 1080p/24 but in some fall back resolution. WHY you dont get THAT option is the real question at this point.
Thanks guys - I thought so. And thanks for the "HUG" ParadoxNope, you're out of luck if your TV won't do 1080p 24. Maybe they will change this in the future, who knows.
Guys I have a Sony KDL-40XBR4 that would not ever play any of the HDPPV movies that were offered in 1080p and I had basically given up. Then a week or so ago, I googled the issue and found someone on the AVS Forum that said that most of the Sony's would work with 1080p/24, only if Motion Enhancer is set to "OFF".
You could prove him right or wrong by simply turning it back on and trying it again. (Unless you already know)...a little harsh.
Oh ok. I've got a TH50-PZ700U. Maybe it does not support the right 1080p.
...Can you get a BluRay player to send a 1080p24 signal to your TV? If it can, and it works, your TV accepts a 1080p24 signal ... if this is the case ... then there is hope that Dish can "tweak" their code that figures out what your TV can do to hopefully someday include your TV ... if such is the case, I would definitely send a support email in to Dish giving them your receiver and TV details.
If the HDMI test does not come back with 1080p24, then the version that you watched would have been the 1080i version.
Limited time offer
