4/8/2009 1:10pm - Uplink Activity Report - 93 changes - STILL NOT VIACOM | SatelliteGuys.US
D
DigiSAT Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 4/8/2009 1:10pm - 93 changes
Uplink Comparison Range: 04/08/2009 12:42P - 04/08/2009 01:10P
Channel Additions:
4648 - KFDX [MPEG4 HD] added to Ciel-2 129W TP 14 Spotbeam 36 (NA)(Wichita Falls, TX-NBC)
4649 - KJTL [MPEG4 HD] added to Ciel-2 129W TP 14 Spotbeam 36 (NA)(Wichita Falls, TX-FOX)
5250(17) - KBMY [MPEG4 HD] added to Ciel-2 129W TP 12 Spotbeam 7 (NA)(Bismarck, ND-ABC)
5250(2) - WBRZ [MPEG4 HD] added to Ciel-2 129W TP 09 Spotbeam 42 (NA)(Baton Rouge, LA-ABC)
5251(13) - KXMC [MPEG4 HD] added to Ciel-2 129W TP 12 Spotbeam 7 (NA)(Minot, ND-CBS)
5251(9) - WAFB [MPEG4 HD] added to Ciel-2 129W TP 09 Spotbeam 42 (NA)(Baton Rouge, LA-CBS)
5252(33) - WVLA [MPEG4 HD] added to Ciel-2 129W TP 09 Spotbeam 42 (NA)(Baton Rouge, LA-NBC)
5252(5) - KFYR [MPEG4 HD] added to Ciel-2 129W TP 12 Spotbeam 7 (NA)(Bismarck, ND-NBC)
5253(26) - KNDX [MPEG4 HD] added to Ciel-2 129W TP 12 Spotbeam 7 (NA)(Bismarck, ND-FOX)
5253(44) - WGMB [MPEG4 HD] added to Ciel-2 129W TP 09 Spotbeam 42 (NA)(Baton Rouge, LA-FOX)
5260(13) - KSFY [MPEG4 HD] added to Ciel-2 129W TP 16 Spotbeam 14 (NA)(Sioux Falls, SD-ABC)
5261(11) - KELO [MPEG4 HD] added to Ciel-2 129W TP 16 Spotbeam 14 (NA)(Sioux Falls, SD-CBS)
5262(46) - KDLT [MPEG4 HD] added to Ciel-2 129W TP 16 Spotbeam 14 (NA)(Sioux Falls, SD-NBC)
5263(17) - KTTW [MPEG4 HD] added to Ciel-2 129W TP 16 Spotbeam 14 (NA)(Sioux Falls, SD-FOX)
6943 - UP29 [MPEG4 HD] added to Ciel-2 129W TP 15 Spotbeam 10 (NA)
7048(3) - WBEP [MPEG2 SD] added to Ciel-2 129W TP 08 Spotbeam 25 (NA)
14177 - KULR2 [EPG] added to EchoStar10 110W TP 04 Spotbeam 36 (NA)(Billings, MT-NBC)
14178 - KTRV2 [EPG] added to EchoStar10 110W TP 25 Spotbeam 41 (NA)(Nampa, ID-FOX)
14181 - WCHS2 [EPG] added to Ciel-2 129W TP 09 Spotbeam 31 (NA)(Charleston, WV-ABC)
14182 - WOWK2 [EPG] added to Ciel-2 129W TP 09 Spotbeam 31 (NA)(Huntington, WV-CBS)
14188 - KLRT2 [EPG] added to EchoStar10 110W TP 18 Spotbeam 15 (NA)(Little Rock, AR-FOX)
14189 - KUSA3 [EPG] added to EchoStar11 110W TP 22 ConUS beam (NA)(Denver, CO-NBC)
14260 - KBJR4 [EPG] added to EchoStar10 110W TP 12 Spotbeam 28 (NA)(Superior, WI-NBC)
14549 - WKOW2 [EPG] added to EchoStar10 110W TP 25 Spotbeam 23 (NA)(Madison, WI-ABC)
14559 - WTHR3 [EPG] added to EchoStar10 110W TP 18 Spotbeam 13 (NA)(Indianapolis, IN-NBC)
14640 - KHGI2 [EPG] added to EchoStar10 110W TP 27 Spotbeam 29 (NA)(Kearney, NE-ABC)
14727 - KLKN2 [EPG] added to EchoStar10 110W TP 27 Spotbeam 29 (NA)(Lincoln, NE-ABC)
14916 - WTVQ3 [EPG] added to EchoStar10 110W TP 04 Spotbeam 10 (NA)(Lexington, KY-ABC)
14943 - KEYE2 [EPG] added to EchoStar7 119W TP 07 Texas beam (NA)(Austin, TX-CBS)
15381 - WMDN2 [EPG] added to EchoStar10 110W TP 31 Spotbeam 11 (NA)(Meridian, MS-CBS)
15382 - WSVN2 [EPG] added to EchoStar7 119W TP 03 South Florida beam (NA)(Miami, FL-FOX)
15383 - WFXB2 [EPG] added to EchoStar10 110W TP 04 Spotbeam 02 (NA)(Myrtle Beach, SC-FOX)
15384 - WFXB3 [EPG] added to EchoStar10 110W TP 04 Spotbeam 02 (NA)(Myrtle Beach, SC-FOX)
15385 - WCAU3 [EPG] added to EchoStar10 110W TP 12 Spotbeam 04 (NA)(Philadelphia, PA-NBC)
15386 - KATU2 [EPG] added to EchoStar10 110W TP 27 Spotbeam 44 (NA)(Portland, OR-ABC)
15387 - KNBN3 [EPG] added to EchoStar10 110W TP 26 Spotbeam 33 (NA)(Rapid City, SD-NBC)
15388 - KXLY3 [EPG] added to EchoStar10 110W TP 18 Spotbeam 40 (NA)(Spokane, WA-ABC)
15389 - KCAU2 [EPG] added to Ciel-2 129W TP 14 Spotbeam 14 (NA)(Sioux City, IA-ABC)
15390 - WTVT2 [EPG] added to EchoStar10 110W TP 27 Spotbeam 01 (NA)(Tampa, FL-FOX)
15391 - WEMT2 [EPG] added to EchoStar10 110W TP 18 Spotbeam 06 (NA)(Greeneville, TN-FOX)
15392 - KGUN2 [EPG] added to EchoStar7 119W TP 05 Arizona beam (NA)(Tucson, AZ-ABC)
15393 - KOTV3 [EPG] added to EchoStar10 110W TP 04 Spotbeam 20 (NA)(Tulsa, OK-CBS)
15394 - KYTX3 [EPG] added to EchoStar10 110W TP 20 Spotbeam 21 (NA)(Nacogdoches, TX-CBS)
15395 - WFXS2 [EPG] added to Ciel-2 129W TP 12 Spotbeam 15 (NA)(Wittenberg, WI-FOX)
15396 - WAOW3 [EPG] added to Ciel-2 129W TP 12 Spotbeam 15 (NA)(Wausau, WI-ABC)
15397 - KCYU2 [EPG] added to EchoStar10 110W TP 12 Spotbeam 45 (NA)(Yakima, WA-N/A)
15398 - WCAV2 [EPG] added to Ciel-2 129W TP 15 Spotbeam 39 (NA)(Charlottesville, VA-CBS)
15399 - WHBF2 [EPG] added to EchoStar10 110W TP 27 Spotbeam 19 (NA)(Rock Island, IL-CBS)
Channel Removals:
212 - CSPN2 (A) removed from EchoStar8 77W TP 12 ConUS beam
216 - C&T (A) removed from EchoStar8 77W TP 12 ConUS beam
281 - HBOLT (NA) removed from EchoStar11 110W TP 21 ConUS beam
282 - HBO-E (NA) removed from EchoStar7 119W TP 02 ConUS beam
283 - HBO2E (NA) removed from EchoStar7 119W TP 06 ConUS beam
284 - HBOSG (NA) removed from EchoStar7 119W TP 06 ConUS beam
285 - HBO-W (NA) removed from EchoStar7 119W TP 19 ConUS beam
286 - HBO2W (NA) removed from EchoStar7 119W TP 13 ConUS beam
287 - HBOFM (NA) removed from EchoStar7 119W TP 08 ConUS beam
288 - HBOCY (NA) removed from EchoStar11 110W TP 15 ConUS beam
289 - STARZ (NA) removed from EchoStar7 119W TP 14 ConUS beam
290 - STRZW (NA) removed from EchoStar11 110W TP 15 ConUS beam
291 - SEDGE (NA) removed from EchoStar7 119W TP 14 ConUS beam
292 - SCINE (NA) removed from EchoStar7 119W TP 14 ConUS beam
293 - STZC (NA) removed from EchoStar11 110W TP 15 ConUS beam
294 - SBLCK (NA) removed from EchoStar7 119W TP 14 ConUS beam
295 - SK&FM (NA) removed from EchoStar7 119W TP 14 ConUS beam
7022 - KTXS (A) (H) removed from EchoStar1 148W TP 03 ConUS beam(Sweetwater, TX-ABC)
7023 - KTAB (A) (H) removed from EchoStar1 148W TP 03 ConUS beam(Abilene, TX-CBS)
7024 - KRBC (A) (H) removed from EchoStar1 148W TP 03 ConUS beam(Abilene, TX-NBC)
7025 - KXVA (A) (H) removed from EchoStar1 148W TP 03 ConUS beam(Abilene, TX-FOX)
7060 - KTXE (A) (H) removed from EchoStar1 148W TP 03 ConUS beam
7061 - KLST (A) (H) removed from EchoStar1 148W TP 03 ConUS beam(San Angelo, TX-CBS)
7062 - KSAN (A) (H) removed from EchoStar1 148W TP 03 ConUS beam(San Angelo, TX-NBC)
7063 - KIDY (A) (H) removed from EchoStar1 148W TP 03 ConUS beam(San Angelo, TX-FOX)
Channel Moves:
212 - CSPN2 [MPEG2 SD] moved from EchoStar7 119W TP 11 ConUS beam to EchoStar11 110W TP 19 ConUS beam (A)
212 - CSPN2 [MPEG4 SD] moved from EchoStar7 119W TP 11 ConUS beam to Echostar6 72.7W TP 07 ConUS beam (A)
216 - C&T [MPEG2 SD] moved from EchoStar7 119W TP 11 ConUS beam to EchoStar11 110W TP 19 ConUS beam (A)
216 - C&T [MPEG4 SD] moved from EchoStar7 119W TP 11 ConUS beam to EchoStar3 61.5W TP 27 ConUS beam (A)
217 - DISH [MPEG2 SD] moved from EchoStar11 110W TP 10 ConUS beam to EchoStar11 110W TP 19 ConUS beam (A)
217 - DISH [MPEG4 SD] moved from EchoStar8 77W TP 29 ConUS beam to Echostar12 61.5W TP 23 ConUS beam (A)
14025 - KTXS2 [EPG] moved from EchoStar1 148W TP 03 ConUS beam to Ciel-2 129W TP 03 Spotbeam 47 (NA)(Sweetwater, TX-ABC)
14975 - KTXS3 [EPG] moved from EchoStar1 148W TP 03 ConUS beam to Ciel-2 129W TP 03 Spotbeam 47 (NA)(Sweetwater, TX-ABC)
Channel Package Flag Changes:
152 - CBS C [MPEG2 SD] - EchoStar11 110W TP 05 ConUS beam changed package flags (A)
152 - CBS C [MPEG4 SD] - Echostar6 72.7W TP 05 ConUS beam changed package flags (A)
5250(20) - WCJB [MPEG4 HD] - Ciel-2 129W TP 13 Spotbeam 53 changed to Available (H)(Gainesville, FL-ABC)
5251(4) - WGFL [MPEG4 HD] - Ciel-2 129W TP 13 Spotbeam 53 changed to Available (H)(High Springs, FL-CBS)
5252(9) - WNBW [MPEG4 HD] - Ciel-2 129W TP 13 Spotbeam 53 changed to Available (H)(Gainesville, FL-N/A)
5253(51) - WOGX [MPEG4 HD] - Ciel-2 129W TP 13 Spotbeam 53 changed to Available (H)(Ocala, FL-FOX)
9250(53) - WQMY [MPEG2 SD] - EchoStar7 119W TP 01 Northeast beam changed to Available (H)(Williamsport, PA-MY)
9250(53) - WQMY [MPEG4 SD] - Echostar12 61.5W TP 07 Area 6 beam changed to Available (H)(Williamsport, PA-MY)
9495(152) - CBS C [MPEG4 HD] - Ciel-2 129W TP 20 ConUS beam changed package flags (A)
9495(152) - CBS C [MPEG4 HD] - Echostar12 61.5W TP 21 ConUS beam changed package flags (A)
19087 - LUDI2 [DATA] - EchoStar11 110W TP 09 ConUS beam changed package flags (A)
19087 - LUDI2 [DATA] - EchoStar8 77W TP 29 ConUS beam changed package flags (A)
Channels in the system: 6402
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
Woohoo, I got my locals. I'm happy. But that sucks that there's no national HD. I asked this questions in another thread and didn't get an answer so I'll ask here as well. I repointed my 61.5 to 129 and am getting a signal of 55 to 65 on the Conus TPs but only about 35 on TP 13 where my locals are. Is this high enough or should I repeak?
I don't remember it... and the uplink report says it was made available today.
I never watched it I know they had the SD version... anyone know?
D
4/7/2009 2:08pm - Uplink Activity Report - 6 changes - NOT VIACOM
D
4/9/2009 3:02pm - Uplink Activity Report - 2 changes
