Channelmaster (the channel editing program) | Page 2 | SatelliteGuys.US
never tried it drhydro. I'll check tonight (maybe..I have to repoint a dish for someone)
thats a good idea as all my 1.2 settings are full right now and I have 3 DBS birds to aim for :)
Thanks Iceberg, looking forward to hearing your results when you have a chance to get around to it.
DrHydro
I checked last night on Channelmaster and each satellite that I have selected for Diseqc 1.2 shows position "0"
conversley, my Coolsat shows position "1", "2", etc for each satellite I stored. I'll look a little more this weekend and might try something with the Pansat 1500 (see if I can override those)
drhydro said:
Iceberg,
Will channelmaster allow you to rename and use the "default" 1.2 sat positions in the pansat? The ones that you cannot save a sat position to.
Thanks in advance....
I was able to do it in GTools. I had terrible luck with CM corrupting the sat / transponders lists on my Pansat 3500s. Be carefull that you don't wipe the skew settings. CM wouldnt' let me set a negative skew value (for +45 / -45) after it zeroed them. CM may have been updated since I messed with it and my problems may have been specific to the 3500s but you can read about the fun I had here:
http://www.satelliteguys.us/showthread.php?t=43483&highlight=pansat
The channel list (well it's really just the sats) I attached might be helpfull for you.
Thanks for trying Iceberg. Guess i will have to try gtools ( Thanks Shawn) , I'll give it a shot on sunday and let ya all know how it works.
Iceberg said:
Shawn
Can you post or e-mail me GTools. I dont know if I have a copy at homeor not
iceberg@satelliteguys.us
It's bundled in the 3500s firmware download from Pansatusa.com. It might be locked to 'just' the 3500s, but I noticed that the file seems identical to what's bundled with the 2700 firmware. I've split it off and attached it:
Shawn
thanks Shawn
With the 1500 unplugged from my setup, I'll monkey with that unit BEFORE I try to do it to the 6000 :)
Speaking of channels, I'm just curious if this program (Channel Master) can be used to upload lists (.bin) into a Microyal FTA that is already set up for DN as we speak but I cant change anything and a few channels have moved TP like DIY and a few porns and I'd like to Edit the necessary changes.
**sigh** some people just can't read
I'll say it slow…… WE ARE NOT A HACK SITE. ASKING HOW TO ASK (OR IN THIS CASE ADMITTING YOU HACK) WILL GET YOU BANNED
thanks TDS, will try it out once I figure how to connect the coolsat to one of my computers, at least all of my laptops do not have the input, I think one of my old desktops might come handy for this
Sat List Viewsat 9000 Neusat 9000
Audio issues on Globovision and ANT1 Greece
