Horizons 2 | SatelliteGuys.US
Horizons 2
Uuhh.... whats a FR ?
Originally from state (#17)
UNITED STATES AIR FORCE 1971-1975
Lackland AFB Tx 1971
Empire AFS Mi. 1972-1973
Indian Mt. AFS. AK. 1974
thats a 24/7 data feed. I've used that TP many times to aim the dish at 74W :)
If it is 24/7, then that WOULD be good TP to utilize for pointing. Thanks Ice!
Like Jim mentioned, since ONN left, I also haven't visited this sat much. Just once in a great while when I am curious if anything has changed. Hard to keep up on what is currently active if you don't go there.
RADAR
74W mainly has sports feeds and once in a while a news feed (a couple news feeds are in S2 also).
They use to be "the" satellite for sports feeds....until 91W overtook it :)
Yes, I remember. A lot of college hockey games. Miami of Ohio was a regular.
Okay guys, I found the 12060, 27692, V signal, but.........by my calculations I am on the posiion for AMC 6 Ku. The reason I say this because I only have to bump it a few clicks to get AMC 6 C band and Saturday night there was an Indiana State game posted on AMC 6 Ku and this is the same position I found it at.
Jim,
You might have to adjust the symbol rate that I posted. That was what my AZBox Premium Plus captured from a blind scan and it might be offset slightly from the official SR.
It would probably work fine, but if you have any troubles I would check this setting first. I don't see thi TP listed on Lyngsat or SatBeams, possibly because it is a data feed TP, so I don't know what the official SR is. It should probably function just fine with a small error here, just be aware of it.
RADAR
Jim,
RADAR
The Traxis is pretty accurate with other receivers, so I figure the feed was gone. I will keep playing with it. I am sure someone will post a game on H2, then I'll nail it. Thanks guys.
Found it. I forgot that there was 5 degree spacing between H2 and AMC5. I was looking for the usual 2 degrees. This development now makes the 12060 V 27692 data feed good on H2, as Radar and Ice said. Now I got to figure out AMC6 C and Ku. Thanks guys.
UPDATE: 2 degree spacing is approx 34 clicks on my 922. I went exactly 34 clicks to the east of H2 and nailed the NBC mux on AMC 6. The C band is a little off from the Ku position, so I will mess with that tomorrow. The only thing that can make this better is Purdue beating Ohio State. Go Boilers.
Legacy Switch and Pilot
Days of Our Lives wild feed on E2 6
