Are there any hot FRs on Horizons 2 that can be used to use to aim the dish. I haven't been there much since ONN left.
thats a 24/7 data feed. I've used that TP many times to aim the dish at 74W12060 V 27692
thats a 24/7 data feed. I've used that TP many times to aim the dish at 74W![]()
Uuhh.... whats a FR ?
12060 V 27692 KS/s FEC 2/3 @ 83%Q RADAR
They use to be "the" satellite for sports feeds....until 91W overtook it![]()
Jim,
You might have to adjust the symbol rate that I posted. That was what my AZBox Premium Plus captured from a blind scan and it might be offset slightly from the official SR.
It would probably work fine, but if you have any troubles I would check this setting first. I don't see thi TP listed on Lyngsat or SatBeams, possibly because it is a data feed TP, so I don't know what the official SR is. It should probably function just fine with a small error here, just be aware of it.
RADAR
Limited time offer
