New open source image for all models of Azbox | SatelliteGuys.US
hello Valasante
Regarding this new SW, did you had to upload the sat list to it or does it keep all the sats? is blind scan working? did you upload the SW by wifi or you have to connect a cable from your computer to the box or USB?
Please let us know.
regards.
Chewie
This software is almost the same as Enigma2 except the name but is open source. The procedure is almost the same as installing Enigma on your Original Azbox firmware. Detailed tutorials are on thier website. I installed it on Azbox Me so I used the web interface (Wifi) but you can use USB key too. You may also install it in a USB key. If you are in the US you may have to resan your satellites or load what you ahve saved. In Europe there are several dozens of plugins already available. You just have to insert your coordinates on your USALS. There is no blind scan at the moment but I understand it will be available for the boxes with harware blindsan Premium +, Me and miniMe very soon since they have nightly builds.
So any advantages over Enigma2 to make me switch? I like E2 on mine so far.
No because is identical to Enigam2 except for the fact that is more stable and there are nightly builds. Therefore corrections partly based on users bug tracking are update online. This way, bugs are corrected quicker.
Ok thanks.. I will be keeping an eye on the nighties for reports
IMHO, its probably better now than OFW although there is a learning curve and I'd probably wait just a bit longer until a few more bugs are ironed out.
Being open source, anything is possible but I'd be skeptical that it would give your Elite blindscan capabilities.
I installed both OpenRSI and Enigma II on my Ultra and no 4:2:2 HD or h.264 HD when tested on CBS and ABC/NBC...not to mention flakey to non existent component output. The menus on the HDMI output is sharp tho....
I'm underwhelmed.....
Are you using switches on your setup and if so do does work with any of the software you mentioned?
curious but are you able to get the 4:2:2 HD-GDMX feeds on 99w?
Hello Gents
I install OpenRSI, I am having a heck of time trying to setup the satellites, does any of you have instructions on how to set them up.
please let me know.
Thanks in advance.
Chewie
Hello Gents
please let me know.
Thanks in advance.
Chewie
Hey chewie. As asked in another thread about the sat lists all versions of AZBox E2 software use 1 .xml file unlike the AZBox orginal firmware which uses more than one. In E2 the satellite/transponder config data are all combined into this one .xml file. As for satellite lists I downloaded a North American sat .xml sat file from here satellites.xml generator / transponder .ini generator and put it into the E2 etc/tuxbox folder using Maz 3.2. Then reboot the receiver. Just remember this file won't have all the current North American Satellites and channels cause it comes from Europe but at least it will have the satellites themselves. You'll have to blindscan for the latest TP's and channels.
Where's the blind scan option located on OpenRSI?
Changing hostname...
Help with azbox premium+ stuck on booting
