We Need Your Help! | Page 5 | SatelliteGuys.US
We Need Your Help!
Lincoln, Ne--looks okay except for one stations location--KHGI (13)-ABC is listed as North Platte, Ne --actual location is Kearney, Ne
Thanks! for the hard work on this!
Sorry, I meant WBDT CW is Springfield, OH WDTN is correct NBC Dayton. My mistake.
Why go by the "city of license" ? That makes zero sense to the average viewer. The viewing "market" is Dayton, not Springfield. WBDT advertises themselves as a Dayton station and their studio is located in Dayton.
SEATTLE:
6415 - 8611 – KIRO 7 – Reads: Mt. Vernon, WA …. should be Seattle
6418 - 8614 – KZJO 22 – Reads: MN – should be IND
6419 - 8617 – KONG 16 – Reads: Everett, WA … KONG is KINGs sister station – Seattle?
6421 – 8620 – KBTC 28 – Reads: Seattle WA … On air they indicate Tacoma
6425 - 8624 – KUNS 51 – Reads: La Grande? … Shouldn't it be Seattle?
8622 – KVOS 35 – Reads IND…It is MEtv … still IND?
PORTLAND OR:
6425 – 8675 – KPDX 49 – Reads MN…should be IND
We have this situation too with our local Ion affiliate, WPXW. It's listed in The List! as Manassas VA, but they moved their offices to Fairfax Station VA and their transmitter to DC at the digital transition. Nothing is left in Manassas except for the FCC license.
If you have the time to go though the 18000 + licenses in the FCC database and then web search each one for local nomenclature , you can do it.
moved to Dayton
SEATTLE:
PORTLAND OR:
will do all
Will change to Washington DC unless you say otherwise.
Ok folks, Nelson61 has taken all your updates and sent me another patch which I just applied.
All information is accurate based on your feedback up until now. :)
Thanks for your help!
Little Rock, AR Updates:
Channel 49, KMYA is affiliated with MeTV. Also, it's located in Camden, AR not Camden, AK :)
Lexington, KY
9209 WKYT2 28 (3 locations.) Still listed as CBS. Should be CW.
Only repeating because Scott said should be ready. :)
Lexington, KY
9209 WKYT2 (28) Lexington, KY - CBS, 28
WKYT2 (OTA 27.2) is actually a CW affiliate.
Lexington, KY
will recheck and redo if necessary
I think it has to do with the way the lookup table works.
Watch for next Scott update and see if the "fix" works
thanks
Ok the update for the Weekend has been applied. :)
Now I think Nelson61 should take a break and go outside for fresh air. Hes been working on this for weeks! :D
2 Hopper 2 Joey questions? Reguarding interface.
Missing program icons
