Do you mean under the Amiko Mini HD SE satellite installation menu, then tp edit, then press the white remote button to add user channel? If so, possibly incorrect video pid or type, audio pid or type, or pcr. Info on sat lists is often out of date. Which channel(s) are you trying to add? Maybe someone can list the correct settings for it.
Well, i was actually, adding a double channel of a channel i already had. Because audio was wrong. So, i mimic'd all the settings and ran through all the video encoding options. Frustrating thing. There seems to be no INFO on a channel that tells you the decoding method. Ie, mpeg1 mpeg2 example. So, i ran through it 4 times trying all the different video decodes.. I NEVER got video. I know i had the right VIDEO PID, because i was copying it from a channel i already had and could see.
Audio on that one can be a pain with that language annoucement on one half of each audio channel. I just gave up and selected the left audio only. I seem to lose that one during the day. Guess I need a bigger ku dish.
