Yes, this exactly.I've seen something that I haven't narrowed down, so I'll throw out what I know....
If you use Netflix and then stop viewing stuff, but leave the app running, when the receiver (or the app ?) goes to sleep, it can be very slow/unresponsive to wake up. Anyone seen anything like this ?
I bet, Dish will probably introduce a few new apps at CES, but I don't think they will be quite ready to be released right then. We'll probably have to wait a little while after CES for anything new.we are suppose to get two or three more apps in a couple of weeks at CES.
Also you can press the remote control blue color button from live TV to find Netflix in the apps menu if you have a HWS only.Where are you guys finding Netflix on your Hoppers? I checked mine and it is not there.
You'd have to re-up for two years, but you can probably upgrade for free.Thanks. Damn I have the original Hopper.![]()
I'm having this same issue with my one Hopper. The remote used for the Hopper does not respond after a while (works for a short time then nothing except turning the television on/off) when viewing Netflix. The Joey (and its remote) in the other room works fine but for now the only way to restore remote function on the Hopper is a receiver reset.Netflix caused both of my Hoppers to lock up. Reset button fixes it.
...1) Prime Time Anytime combined with sports (mostly football). When setting up a timer for a Non-PTA game (Sunday afternoon for example) the end time is automatically set to 60 minutes past the guides end time (which is great for games that are longer than scheduled or for overtime). However, Sunday night football usually goes past 10pm (CST). So, all of the Sunday Night Football game recordings get cut off some time in the 4th quarter. I can't tell you how many games I have watched that get to the 4th quarter in a good close game and it gets cut off. You might say, "Just set up a timer to record the game and set the end recording time to 60 minutes." My answer: It's really difficult to set up a separate recording for a show that's in PTA. And, even if you can maneuver around it, I am pretty sure that the separate timer does not create a separate recording (with the additional 60 minutes)...
Does anyone see the spinning circle with a % counter ? It's almost like an indicator that it's buffering but it will frequently just get hung up (25% seems to be a common point for me). I am hard-pressed to say that I have ever seen a buffering problem with my TV's Netflix app or the Netflix app on my Roku.
Limited time offer
