I just received a replacement Hopper (third one so far) and it is refusing to connect to my two wired Joeys. Probably something I missed during initial install. How can I reset everything and start over as if I had just unboxed the new receiver?
We will need you to reset the entire system. The proper way to reset the system is done in the order listed below.
*If you do not have the device in step 3 and 7, please skip to the next step.*
1) Unplug the Hopper
2) Unplug all of the Joeys (or pull out the power adapter)
3) Unplug the Hopper Internet Connector (you may not have this part if the Hopper is connected via Ethernet)
4) Wait 10 seconds
5) Plug in the Hopper
6) Plug in all of the Joeys
7) Plug in the Hopper Internet Connector
After you complete these steps, will you please tell me what you see on your screen?
4) Wait 10 seconds
Right. That was why new one was sent. Current issue is with replacement Hopper.He was responding to the question of why he had to replace his Hopper.
Apparently the Hopper is working, so it was.They won't connect unless you have the hopper ACTIVATED
I have 119 sat feed into my eastern arc 1000.4 sat dish ,just because of this problem. When ever I got a new receiver or replacement hopper it always defaults to looking for 119 sat ,no matter that I have eastern arc. I finally got tired of this happening and added the 119 sat on another dish just to be able to get any hopper or new receiver up and running without all the drama.When I got my replacement Hopper I had to do a couple of check switch tests before the receiver would stop looking for 119 and look to the Eastern Arc. It would just sit and say acquiring satellites. Had to do the hard unplug routine a couple of times and then it finally got itself righted.
Limited time offer
