This may or may not be part of the problem. Specs were not as originally described and there have been a number of issues with this receiver which the distributor has been trying to work out with firmware releases. Some dealers are offering returns and full refunds because of this. See more here (long thread but worth the read): http://www.satelliteguys.us/xen/posts/3699918/GeoSatPro HDVR3500.
I really like this unit because of XBMC. Maybe titanium can point out a firmware download?Update? I bought it from him.This may or may not be part of the problem. Specs were not as originally described and there have been a number of issues with this receiver which the distributor has been trying to work out with firmware releases. Some dealers are offering returns and full refunds because of this. See more here (long thread but worth the read): http://www.satelliteguys.us/xen/posts/3699918/
Possibly. I don't believe he's even selling these anymore because of the issues. I've done business with him before and I'm sure he will help you if there is something that can be done on his end.I really like this unit because of XBMC. Maybe titanium can point out a firmware download?Update? I bought it from him.
I bought it over two weeks ago. If someone could post a firmware update download link, I would be happy to do a YouTube video for the unit as a fix IF it works. Of course I would have to start a new thread for that and i would post the link. For now I will wait for that and get my dish up and going one way or another. Got to get this problem solved first.Possibly. I don't believe he's even selling these anymore because of the issues. I've done business with him before and I'm sure he will help you if there is something that can be done on his end.![]()
Much appreciated. Sorry.. I had car problems all weekend and have had to halt progress on the sat install to fix the car. I did however zip tie a lnbf " universal" to the dish. What a world of difference. But geuss what? still cant pull in galaxy 19. I am thinking about placing dish skew at 90 and setting the lnbf to skew settings of dish and work backwards from there. I think the dish size really limits signal.Glover31, Check out post #562 for the latest USB firmware update. http://www.satelliteguys.us/xen/posts/3730770/
Hadn't heard of lock-ups during the install. If you enjoy using the unit, I will certainly attempt to support your install!
FTA4PA is correct. We no longer sell the HDVR3500 due to unresolved issues, but would be happy to refund and suggest alternative products. Give me a call.
Or trees for that matter... Just working with what I got.. Don't have much after the divorce so that's basically it. Little meter with needle. I did however also have a small tv and using the meter on it via the receiver I bought from titanium. Ironically enough, I managed to get it all up and going last night. What I did is use the dish with no skew "so 90" and rotated the universal lnbf inside the tie strap and boom. Got it. Actually I pulled in 95 west first then I got 97. Thing is....... elevation is at 50. Not 37. I went back and rechecked EVERYTHING. Cause that doesn't make any sense. Things were only a little off as far as level. Yet, after all adjustments were made still I was at 50. 50. And at 50 I was able to hit sats left and right just for giggles. I guess if all else fail's throw away the instructions. Mua ha ha ha ha!. So from this point I worked backwords by simply turning the dish skew slowly to 70 and the lnbf to 0 a little bit at a time. I have signal 70+ and quality is just over 50. Pictures to come. Trying to find my data cable to hook my phone to the computer to upload them. Hopefully I will have the correct lnb and scalar ring by Friday.Agreed those little meters with just a needle and nothing else is almost like doing it without one. It is just a single transistor or OP amp circuit and will deflect the needle if pointed at anything electric and electronic.
I hope you didn't take what I said wrong, was not inferring that you are cheap, or beneath anyone for not buying a $1000 meter.Or trees for that matter... Just working with what I got.. Don't have much after the divorce so that's basically it. Little meter with needle.
Glad to hear! Always a good feeling to actually get that first signal!Ironically enough, I managed to get it all up and going last night.
I'm not done yet. Now its on to the lnb that belongs on it with a scalar ring.Glad to hear! Always a good feeling to actually get that first signal!![]()
Thats what I was thinking last night.. but.. guess what? No signal. Notta nothin. With this scalar ring I get same results as the first time I used this lnb. I am thinking its junk. But before I chuck it in the trash " so discouraged" , I thought I would finally get to uploading the pictures I have taken as I have gone along. Also this lnb with scalar ring I just bought has me baffled. Why would there be skew marks on this? The darn thing doesn't adjust. It has 4 screws but they don't let it turn or anything like that.If the temporary LNBF feed horn opening is at a different height than the original, the dish elevation will be adjusted to compensate for the difference. When you swap for the OEM feed-horn/scalar, the elevation will require adjustment.
Take off the blue conical scalar. That is used on C-band feedhorns on offset dishes and has no purpose for mounting the OEM feedhorn/scalar/LNB on your reflector.
The OEM scalar feedhorn is mounted on the feedarm then the dish will be rotated 19 1/2 degrees counter clockwise (standing in front of the dish).
The OEM feedhorn mounts with either the two screws through the tabs into the LNB riser or if the riser has its own clamping top cap, clamp onto the round portion of the feedhorn.
Good, correct LNBF! Be sure the receiver' LO frequency is set to 10750.
You were informed correctly, the LNB requires a feed horn and scalar. Not sure how a LNB could be mounted on the 75e without the feedhorn and scalar. Surprised that anything was received! Definitely want to see a photo of how this is mounted. You either need to also install the proper feedhorn/scalar or replace with a LNBF.
The receiver will not display Signal Quality unless it is placed on an active transponder. On G19 KU, I recommend using transponder frequency 12152 / Polarity Horizontal / Symbol Rate 20000 as a good active transponder to locate G19. Sweeping the sky and Blind Scanning is a very slow and difficult way to locate a satellite. Like you, I would also be very frustrated with this method.
Limited time offer
