That or the OP has one of them cheap 4K tvs.
Sent from my SAMSUNG-SM-G900A using Tapatalk
LG 65EF9500 not I cheap 4k tv lol
Without going back through the whole thread, did you reset your TV by unplugging it, or try a different TV?
And where did the OP state this was his model tv?LG 65EF9500 not I cheap 4k tv lol
Sounds like the TVs main board is bad or is not compatible with the new Hopper 3 that can do 4K. To get full HD the HDCP Copy protection needs to pass, else the TV drops.
I reproduced the issue yesterday on a generic cheap TV
And even still you are paying a premium for early technology at an extreme premium price thinking you are actually coming out ahead.
That's the typical uneducated consumer.
If you have vizio4k, put to 720p, not 1080i, it will still play Netflix at 4k, or 1080p.I calibrated it on the Expert ISF setting and with the H2 I was pretty happy with the picture but with H3 it easily looks below DVD quality. With Blu Ray it looks great and with any streaming 4k content it is fine but not the H3.
As troch says, the H3 does not do any converting just output, so any satellite chanel will either be 720p, or 1080i (unless 1080p vod), so the TV will then take either signal and upconvert to 4k. Reviews on vizio say it is better up converting 720p, vs 1080i. This is up to each TV and their upscale engines...If you have vizio4k, put to 720p, not 1080i, it will still play Netflix at 4k, or 1080p.
I don't have a Hopper 3 , But I find it very hard to believe the Receiver has anything to do with the PQ since it doesn't do any converting at all.
After reading all this, it does appear to be a HDCP handshaking issue. You said everything was the same except for the Hopper and the LNB, but a big difference is no more AVR in the middle, which that receiver may have been doing the proper handshake with your old Hopper for the signal to the TV. Perhaps the TV has no problem handshaking on 4K content but is having an issue with HD. You say the AVR can't handle the Hopper3 4K signal, but could you at least hook it up temporarily to see if the AVR solves the HD problem?
Did we see suggestion of that previously?![]()
Did Tech try out another set of HDMI cables? I know you have said not a cable issue before, but I would still try out a set of component cables for the hell of it. You just never know.Tech came out this morning and pretty much told me to go back to a Hopper 2 until they fix the issue with a software update. So basically did nothing.
I have bad PQ on every TV in the house now it is just much more noticeable on the 65 inch LG
I did try through the AVR just for a test and still has a bad picture.
Limited time offer
